Since my last post we have gotten a lot accomplished. We sprayed in about 50 bags of R13 blow in insulation, with a machine we rented from home depot. That was a great experience, the machine was broken and we had to fix it. One of the motor mounts had broken and the motor had fallen closer to the floor, and rubbed a hole in the hose...which made it nearly impossible to spray insulation, we riged it up to work, but it took much longer than it should have. After we had blown the insulation in we were finally able to put the covers over the attic access holes.
After that we were able to move onto other things, because the insulation was finally out of the way. We sprayed the pegboard with an aluminum oxide paint, and put a clear over it to make it semi-reflective. In the pics it looks splotchy, but it's really not nearly as splotchy as they appear, they are just dirty from sitting. We also got around to putting all of the switch and outlet covers on. We hung trim as well, using some sort of vinyl that was supposed to be used to seperate the individual pieces of pegboard, but did not work out. Since we had lots of extra pieces of it left over, we used trim nails to hang it as trim..and it actually looks pretty friggin good.
We finished all of that yesterday, last night my dad put shelving in on top of the block, we have 8in on one side and 12in on the other. It really doesn't get in the way of anything, and seems plenty sturdy.
We also got the loft finished out, painted the loft floor, installed base trim and got all of the covers in place, but my battery ran out before I had a chance to snap a pic or two of it. We've also gotten a lot more 'invisible' work accomplished, and we are steadily moving along. The fact that I have started school again has taken a hit on our progress though, but its still not that big of a problem. Hopefully this weekend we will be able to pressure wash the floor and start coating it.
:2thumbs:
