I finally did it! The weather cooperated yesterday so I did my first real wash. Thank you again to everyone for the advice! Part of the process went as expected (ONR), part went a little worse (clay), and a couple parts went better than expected (KAIO & 845...I almost feel that I may have done something wrong b/c they were TOO easy!)
I apologize for my lengthy follow-up/further questions (and I know some of the questions should probably be in their topics), but I greatly appreciate any further thoughts/suggestions:
1. ONR wash: went perfectly fine and about as expected. I used a Meguiar's Microfiber Wash Mitt & Viking Microfiber Waffle Weave Drying Towel. I was happy with both products and would use them again. I do have a Zwipes 757 Microfiber Hand Mop, but I didn't try it b/c I thought I read that ONR is better to use with a plain MF towel or mit, vs. a hand mop which doesn't provide as much coverage.
There are a few remaining 'bug splats' on the hood/grille which I just could not get off. Any recommended products/techniques for doing so? Though they've been there for a while and might not come off by hand...
2. Claying: didn't work for me. I don't know what I did wrong (or I did nothing wrong and the
clay isn't supposed to get out those remaining bug splats, possible white paint specs, etc...?). I used ONR in a ratio between clay and QD (to be safe), and found that the clay just didn't really get anything off (Pinnacle ultra poly clay). I did feel it drag occasionally and then free up, so I guess it did 'something', but it didn't remove anything 'major' (and it came up pretty clean, no big dirt particles trapped by the clay). I only used it a bit on the hood and one side panel, but gave up after it didn't really seem to be doing much (and I didn't want to risk doing something majorly wrong and messing up my paint...).
Could it just be that my car is new/clean enough that it didn't need claying? Any further thoughts/recommendations would be appreciated.
3. KAIO: applied with a Viking Microfiber Applicator Pad and it went on/off quite easily. I applied to 1 or 2 panels at a time (depending on size of panel) and then wiped off with a clean MF towel (regular MF, not super plush or anything like that --
should I have used a super plush towel?). I had a little trouble in that the areas where I did my first pass, as they had a lot more product than the areas at the end of a panel. These areas were then much harder to buff off, and I found myself applying the product quicker and quicker so I could go back and start wiping those first areas. I was putting a small amount of KAIO in the middle of the applicator pad, and basically that drop went on really heavy when first applying, and then I guess it got distributed around the pad and the rest of the panel went better.
4. Collinite 845: applied with a Viking Microfiber Application Pad and it went on/off quite easily. I'm so glad I read this forum over and over regarding the 845. When I first opened it, it was nearly solid! I held it in my hands for a while but nothing really changed, so I ended up putting it in a cup of warm water for a few minutes, shaking, warm water, shaking, etc... Eventually it turned into a nice thin liquid. I slightly dampened the Viking pad with water and applied a small amount to 1 or 2 panels at a time (depending on size of panel) and then wiped off with a clean MF towel (
again, would a super plush be better?). Also, after seeing how one drop in the middle of the pad didn't work that great for the KAIO, I instead did 3 smaller drops in a row across the diameter of the pad. This seemed to allow for easier application.
After reading a lot of posts where people had issues with 845, I have to say that I was surprised by how easy it was. The product did look quite oily when applied, but it wiped off no problem with a MF after just 1 or 2 panels, or even a few minutes later (on spots that I missed).
My concern with the 845 (and I guess this applies to the KAIO as well), is that
maybe I should have used a foam applicator pad rather than MF applicator pads. Perhaps the MF absorbed too much product (especially in the case of 845), and that's why it was so easy to remove (b/c I didn't put enough on)? Perhaps a foam pad would have made the KAIO goes on more consistently? Or I am just that good (and you all give such good advice) that I just did a perfect job with the KAIO and 845?
I also have a question on cleaning my MF products but figured I'd make a new post for that:
http://www.autopia.org/forum/car-de...2462-cleaning-mf-products-after-wash-wax.html
Again, thank you in advance for your further comments/suggestions!
Thanks again!!!
