pwaug said:If not trying to save time, but aiming for the best possible outcome is it best to clay first then use IronX?
TOGWT said:
a) Detailer's clay - removes paint surface contaminants i.e. it abrades the top section of an iron particle, leaving what is below the paint surface to remain.
Jesstzn said:I'm not jumping into the foray here but I find this statement very difficult to fathom. I can't see how something as soft as clay can "abrade" an iron particle that is somewhere around 4 - 5 on the Mohs hardness scale. I would have more of a tendency to believe the stickiness of the clay pulls the iron particle out of the surface.
If it can abrade iron why can't it abrade a fine speck of tar from the surface using the same logic? Thats because the speck of tar is stuck to the surface and can't be pulled out like the iron particulate.
As for the product changing color as it does its job.. Is the color change created when the product reacts with the iron or the iron oxide (rust stain) ?
Jesstzn said:IAs for the product changing color as it does its job.. Is the color change created when the product reacts with the iron or the iron oxide (rust stain) ?
TOGWT said:Of course your'e right, what was I thinking, detailers clay 'pulls' particulates from the surface, they only include abrasives to mar the paint
Thank You .. so basically if I clayed the panel and it pulled the iron particulate out the brownish stain left can create the purple reaction.PiPUK said:As to what 'iron' is reacting, it is the iron salts, the oxides here, not the metallic iron.
Accumulator said:You needed to do something a bit more blatant, like [sarcasm]...Of course your'e right, what was I thinking, detailers clay 'pulls' particulates from the surface..[/sarcasm] to get your point across
The point being that clay works via shearing not by "pulling". Clay glides along on top of a film of lube until it bumps into someting, like contamination, which it then shears off. Yeah, *sometimes* that shearing action will also yank the contaminatin out of a depression/pore/etc. in the paint, but that isn't the norm. So *usually* the clay leaves a bit of contamination behind, the little bit that's below the surface of the paint. That's why rust-blooms are *MUCH* more likely to "come back" after claying than they are after chemical decontamination (I like clay and use it all the time, but this was exactly my experience).
IMO (based on IME) clay seldom causes significant marring IF (and it's a mighty big "if" indeed) you use gentle clay, lots of lube, minimal pressure, and you keep kneading/replacing the clay often enough to keep contamination from turning it into sandpaper. I'll sometimes knead/replace clay afte moving it across the paint *one time and one inch* and I doubt that many people bother doing that.
Jesstzn said:Thank you .. maybe you should change your data base to reflect this![]()
TOGWT said:I answered this question on another website that Jesstzn is a moderator on and got very put out about it so I hoped someone else would enlighten him.
Thirty year old simplistic abrasive technology and its still missunderstood - wow
Jesstzn said:I guess we will really never know unless a clay manufacturer chimes in and I doubt they will. The shearing theory is wonderful but...
that's like telling me that I could take clay and run it over an iron file and shear off the teeth because they are sticking up...
And if it shears off something it bumps into why doesn't it shear of the fine particles of tar that protrude from the surface?
My theory regarding clay and rail dust ( iron particulate ) ;
A) Clay pulls the iron particulate out of the spot that its imbedded in.
B) Clay doesn't do much for fine tar particles because 1) It can't dissolve it, 2) It can't shear it off even tho tar is no where near iron on the Mohs hardness scale. 3) Tar is adhered to not imbedded in the surface.
C) Clay has abrasives in it to abrade away the iron oxide stain left after the particle has been pulled from the surface.
A compound on a yellow pad will cause marring on paint where properly used clay won't BUT the yellow pad/compound combination won't shear off iron particulate sticking out of the paint surface.
As far as claying and rust blooms coming back , unless you plotted every bloom you had on some form of scale you will never know if it came back .. or its a new one.
Maybe one day a clay manufacturer will chime in ... not a reseller with their opinion.
Accumulator said:a) I've had rust-blooms "come back" even though the clay appeared to get all the ferous contamination. I figure that's because there was still some stuff left in the pores/etc. of the paint. Chemical decontamination worked better for me in this regard; the rust-blooms never "came back". And you know for a fact they came back and weren't new ones? I even tried to photograph the panel and still can't be sure if they are old or new? Did you go this far?
b) Again, clay works perfectly for tar removal *for me*, and does it without stripping my LSP (at least it works that way 99% of the time).The tar I am speaking of isn't on my car and not fresh its usually months old and hard. Yes I can use Varsol to remove it but it still doesn't explain why clay doesn't shear it like like it supposedly shears sintered iron.
pwaug said:What would account for the appearance of only a few purple areas???
Jesstzn said:Simple... You take too good care of your stuff..:bow:bow
pwaug said:Hey, I've had good teachers--still use my wheel shield built to your specs to protect the LSP on the wheels when cleaning the tires.
