tableturns said:
foxtrapper, how do you tell when the layers start to dissapear?
This late spring/early summer I used a sharpie and marked layers of SG on the hood of my truck. I went up to something like a dozen or 20 layers applied back to back on one side of my hood, and I think I got as far as 6 or 9 layers spaced out daily on the other side before I got side tracked. Nothing in the center. The areas were all taped off, giving me that really cool checkerboard look. As I recall, I put a number down on top of each layer as I went. This gave me sequential numbers under multiple layers of SG. As a layer of SG disapears, the sharpie ink on top will go with it.
So I watched. I did absolutely nothing to the hood. No washing, no QD, no touch-up's. Nothing but watching.
For quite a while, nothing happened. Then the shine & numbers started to fade away. I wasn't paying close attention, but it seemed that when things went, they did it all pretty quickly. As in there wasn't much difference between the areas with just a few layers, and those with many. The old "she's holding, she's holding, she's breaking up" bit. But again, I wasn't diligently monitoring this, so hold it a little suspect.
At this point, early fall, there is absolutely no SG on the hood. Nada, zip, zero, gone. The paint is all nicely faded and chalky, rubbing off on your fingers should you wipe it.
While I didn't keep rigorous control of this test, there are a few tentative conclusions I've been able to draw from it:
1, SG doesn't last that long. A few months at best.
2, WOWO or 24 hours of waiting doesn't seem to make a difference.
3, Many layers don't last that much longer than just a few layers.
There's another person on this board doing essentially the same test. I'm curious to see their results when they are done.
As for using a QD between layers, I don't like the idea due to chemical residues and bonding. It may well be a non-issue, but the boat builder in me doesn't like anything that interferes with the bonding of layers.
