imported_Intermezzo
jgv said:You're not maximizing it's cleaning ability using a cutting pad, what you're doing is rubbing a somewhat harsh foam pad in the surface, a pad designed to be used with compounds to remove more severe damages on the paint. What happens when you use it with finishing product is that you're causing marring to the surface.
Uhm, actually, using a cutting pad does increase a polish/cleaner's effectiveness.
Don't knock in theory what works in practice. I'm gonna have to agree with BillNorth on this one.
http://www.autopia.org/forums/showthread.php?s=&threadid=23482
Quote, "after I buffed out the AIO I considered going over it again with DACP but there really wasn't a need. It was a pretty clear surface without any marks"
This thread shows what AIO can do when applied with a Maroon cutting pad. One poster even states that AIO is more effective with a rotary.
And finally, in MY experiences with AIO, it's one of the few products that can be applied via a cutting pad without leaving any hazing or marring. In fact, AIO & 1Z's Metallic polish are the only two that *I* am able to apply via yellow CMA pad with no left-over marring.
