byalegend said:
This is a car I plan on keeping forever - love it!
Good call!!
ThatGuySkye said:
This makes me wanna go buy a legend to commute in. LOL
You should. They can be found cheaply but as with any used car should be checked out carefully for known problems. PM me if you decide to move forward with it and want any Legend-specific advice or feedback.
Accumulator said:
That somehow strikes me as really cool!
I guess changing the wheels is how I manage to not get bored driving the same car for nearly 8 years.
JJ_ said:
what Microfibre do you use to remove the wax?
Honestly I don't know what brand they are - most of my microfibers are the blue ones that come from Griot's Garage.
2007TBSS said:
Thanks!
BluBrett said:
Is it hard waxing around the L E G E N D letters?
Yeah, that area can be a bit of a pain. Toothbrush comes in handy sometimes
Intercooled said:
Hopefully i can post here 10 years from with my H2!
I hope so too! Good luck with your Hummer.
sontakke said:
The prices charged are astronomical for some of the items (over $300 for brake cylinder cap with built-in switch??). Also some items seems to be repeatedly being changed.
Correct - here's your list again:
Main relay & fuel pump & fuel filter replace $950
Yes, this one hurt, especially because I was at around 399,750 miles and was so anxious for a big milestone!
Replace front wheel liners $400
These are mostly my own fault. Lost some of the plastic screws that held them in and tried to get by without them. The wind would catch it, tire would rub, and eventually it gets ripped out.
New clutch master cylinder and new PS fluid $411
Yeah, spendy. 382,000 miles for this service.
New clutch master and slave cylinders $414
This one was at 90,012 miles. So technically I got 292,000 out of a clutch master cylinder.
Brake master cylinder cap & switch $300
This was at 54,000 miles - before I owned the car. There were also a number of other items done at this appt besides the master cylinder cap - checklist of maint items for a 50k service; alignment; oil change.
Brake master cylinder $342
This was at 80,000 miles - also before I owned the car. Has not been changed since.
Radiator tank $463
This record is from 63,000 miles, before my ownership. I had the radiator replaced at 169,000 with a Koyo and then at 328,000 with Honda OEM.
Bunch of timing belts and water pump; every 60-90K $900 each
Yes, unfortunately this is standard Honda protocol. I'm coming up on another one currently. Otherwise it's been nothing but oil changes since the 400k mark.
AcuraYYZ said:
Why did you not use a private mechanic specializing in Honda or Japanese vehicles?
nygoat03 said:
why not do alot of the work urself??
In my shopping around locally, the "specialty" shop rates are nearly as expensive as the dealership, and I have the peace of mind knowing that the dealerships know me and my car and take care of both. Flexible scheduling, loaner cars, customer lounge, and 100% OEM parts. I don't have the time, know-how, or tools to do my own maintenance. I'd rather pay someone else to do it because I can get more value of my time doing other things. Detailing is an exception. I ALWAYS decline a wash at the dealership.
Florida-LS said:
They are very comfy! Easy to make a 1,000 mile drive in this car and not get fatigued.
dklac096 said:
Beautiful car and pics. I be jealous.
Thanks
turboawd said:
where did you get the protective clear film that is on the plastic part of your doorsills? is it an adhesive film that sticks onto the plastic doorsill?
Yes - the "Dealer Must Remove" film I originally got on Ebay. It's just a sticky-back plastic. It came in a 200 foot roll, 2 feet wide. It's perforated and you can tear off however much you need and then cut to fit.
Here is one distributor I found.
Dealer Must Remove - Self Adhesive Auto Floor Mats - Car Floor Mats - Carpet Protection Film
Accumulator said:
Lots of reasons to do/not do mechanical stuff yourself, including knowing the limits of your abilities and simply not wanting to spend your time doing that instead of doing something else.
Bingo! You know where I'm coming from.
Just under 420,000 miles at this point FYI.
