killrwheels
actually it is co-owned by one of the owners of Pinnacle Waxes. Read the bio page , as the creator also made the line "Detailers Pride" .
killrwheels said:actually it is co-owned by one of the owners of Pinnacle Waxes. Read the bio page , as the creator also made the line "Detailers Pride" .
Horseman2475 said:Can you apply the Sealant in the sun?
My experience was much the same as Mr. Clean's . . . I used a PC and white polishing pad, spread the polish at 3-4, then cranked it up to 5-6 and worked it until it began to disappear and dry a bit. If I tried to wipe it off immediately, it tended to smear, and required several wipings to remove completely. I discovered that if I let the residue haze and dry more completely, it buffed off more cleanly/easily, but with just a little more initial effort to "break" the haze. I ended up doing about a 1/4 of the car at a time, then going back to remove residue; seemed to work OK. I also discovered that the polish goes a very long way . . . once the pad got primed, it only took six or seven small dabs (pea-sized) around the pad to do 1/2 panel.roadchief[/i] [B]I applied the pre-cleaner with my pc on 3. went on great but if i let it haze too long i needed the detail spray to remove the residue.It gave a nice shine and i really was pleased with the result.[/b][/quote][QUOTE][i]Originally posted by Mr. Clean 2K said:I precleaned the wqhole tundra before I removed it... Put it on thin and you have no problems...
killrwheels said:Never seen a synthetic sealant do beading so small , and uniform. I am impressed ! :up
jgv said:Have you seen Zaino beading?
Meh....not me. Not until digital equals print.
