TOGWT said:<span style="color:rgb(0,0,205);">I'd second this.
FWIW- I use Opti-Coat and then an organic wax![]()
Which organic wax(es) do you like on Opti-Coat?
GBynum said:My plan was to wash, polish, wax, then wash and wax again per your suggestion. I have clay barred before, but I was recently told that is abrasive and shouldn't be done unless necessary.
GBynum said:I have clayed the entire thing since I bought it. I didn't even know "rail dust" was a thing. Do I really need to do it every time I do a full detail?
bert31 said:I would clay about once a year or more. A decon routine can take that claying's place though.
bert31 said:So long as you are not using medium or stronger clays, you should be fine. I like to clay about twice a year or maybe three times a year.
Another thing I like to do is when decontaminating my car, during the B step which is the acid step, while the acid is dwelling on the paint doing its job, I will clay that spot (the acid is actually a decent lube). Claying an area with the acid on it is clay using clay on steroids. If you do the same, toss that piece of clay when you are done, it will be in pretty rough shape after the acid.
Accumulator said:While it's not a hotness-type product, if you want to use a wax I'd simply get some Collinite. Their 845 liquid doesn't stain trim. Note that Collinite waxes are probably closer to sealants than to "waxes", but IMO that's immaterial. Good durablity, protection, and IMO looks.
Accumulator said:BlueBeast14GT- Are you certain that *I* said you can't layer a true wax? If so, then I misspoke as I wouldn't want to generalize like that and the waxes I use *do* layer.
Accumulator said:Heh heh, note that FK calls FK1000P a "wax" but it's a sealant. The words "wax" and "sealant" almost become meaningless in the practical sense.
Accumulator said:The words "wax" and "sealant" almost become meaningless in the practical sense. I think of it this way- if it's basically synthetic stuff as opposed to" basically natural stuff from a tree" then I think of it as a sealant or a hybrid. And I don't make a big differentiation between sealants and hybrids.
Eh, I don't make a very big deal out of these diffs at all! I bet I usually just think/say/post "LSP" and let that cover all the bases.
Accumulator said:"Glaze" is like a temporary LSP, one that's usually water-soluble (i.e., washes off even just in the rain). But note that Meguiar's calls their glazes "pure polishes" these days (they didn't used to back in the day) so who knows what a given term means?!? It's another case of where different people use certain words *so* differently that those words lose (their proper, singular) meanings, which drives me nuts.
WWWW-WillyWallyWashWax said:2. http://www.duragloss.com/Exterior-Polishes/Polish---Cleaner/8-oz.---Duragloss-PC-(Polish---Cleaner)
3. http://www.duragloss.com/Pre-Polishing-Agents/Swirl-Mark-Remover/8-oz.---Duragloss-SMR-(Swirl-Mark-Remover)
1.http://www.duragloss.com/Pre-Polishing-Agents/Polish-Bonding-Agent/8-oz.---Duragloss-PBA-(Polish-Bonding-Agent)
Some companies like Duragloss really confuse this issue now.
Their terminology had stopped me from issuing from them every time.
Look at this product link 1. above.
Bonding a polish like an epoxy?
Polishes just fix paint, why is bonding needed?
Product 2 is a polish but says that it Makes a coating.
Obviously, there is different terminology being used.
Product 3 is listed as "pre polish agents"
It is titled a swirl remover, but had polish and wax in it?!
Why would I wax pre polish?
There is a reason why you can be easily confused....
It seems companies are confused themselves.
