Review on Collinite 845 Insulator Wax
just to let you novices (ha,ha) know...i've been using IW since 1977. yes, 1977. this stuff has been around along time. it's a mistery why they don't push it to the general public. i found out about it from a friend who worked for the power company.
petp said:
...this stuff is so powerful, how the heck do you take it off in the springtime? it says its 'detergent-proof', so im assuming a dawn wash will do nothing to it?
Dawn doesn't do much wax stripping anyhow, and it sure doesn't dent Collinite for me.
Paint cleaners cut right through it though, Meg's Deep Crystal Step #1, AIO, SRP, stuff like that'll do it. Or you could use rubbing alcohol. Or you could just let the abrasive (that you'll probably need after winter anyhow) cut through it, which is what I usually do.
I like #16, but for the winter I put some 476S over top of it (wife's car, she uses it for long trips). Come spring I just use a mild polish and go back to #16.
I wouldn't worry too much about pre/post VOC versions of IW. I've yet to hear of any issues with the newest version. But then I'm the guy who bought a case of 476S before the change just to be on the safe side :o
Nope. Just try to wash it out from your applicators. I waxed a Fiat Punto with it yesterday. I threw my app into the washing machine - full cycle. Then APC, soap, shampoo and a little bit of vinegar. I rinsed out then sqeezed all possible moisture out from it with terry towels. The I took the moist applicator, and waxed my bathroom mirror with it quite comfortably. That thing is a jaw-dropper.
I must pre-soak my app in IPA + other wonders...
You put 476 on top of the IW? Can you do it the other way around to get durability with the superior (so I hear) finish of IW?
mb
Accumulator, you and I have much in common, first it was 3Ms PIII RC, then it was #16 and now its Collinite 476S. You must be a conservative common sense type of guy !
I used IW on my silver 307 last week. Not quite as wet as Nattys but still very impressive. I didnt bother with pictures as silver never looks as good in a photo.
*BUMP*
11 posts up.
Wanted to know if they still have the Old 845 available anywhere.
Are you guys using the new 845? IS the durability relatively the same? Better?
Wannafbody, tubler,
Thanx for replying.
So basically no place ONLINE has the Old IW?
I drove half and hour to the closest Advanced auto parts and the lady doesn't even know about the product and was so careless in helping me. She's like "What ever we have on the shelves is all" I feel as a store employee you should at least have somewhat of an idea of what you sell) she didn't bother to leave past the register, quit chatting and help me.
Oh well, I gotta move on.
I hope somebody finally does a side-by-side with the "new" and "old" versions of IW just to put this thing to rest. I'm gonna be very surprised if there's a noticeable, functional difference. The folks at Collinite worked on the new formula for quite a while and I have confidence in them.
EdLancer said:
Accumulator, you and I have much in common... You must be a conservative common sense type of guy !
Heh heh, well, I do try to be sensible, and my more liberal friends would agree with the conservative part ;) I *am* pretty conservative on the detailing products. Stuff that's worked fine for me since forever still works fine today.
Sorry, I must've been unclear, I don't use IW, just the 476S. It seems to layer just fine on top of most anything. I dunno if the IW would compromise underlying products or not, I'd wonder about the solvents in it but I don't know for sure.
Sherman8r44 said:
Would a touchless automatic car wash remove it?
Depends on the carwash- what detergents they use and how the mix them. The touchless my wife goes through in TN doesn't strip #16 or 476S but that doesn't mean a different wash wouldn't. It's a gamble.
I ordered mine from PakShak and I got the pre-VOC bottle. This was a few months back so I'm not sure if Ranney still has anymore left.
Also, 1 layer of this stuff went 3 months easily for me (half of it through the Melbourne winter) and it was still beading like new. After that I stripped it off. Was very impressed but couldn't wait to try something new.
I started using 845 this past Sept. I already have 3 coats on the car, and I
plan to doa fourth probably before the end of this month. Now that I've had
time to play around with it, here are some more little observations:
It wil definitely hide light swirling and cobwebbing with multiple coats.
It leaves one of the clearest shines I've seen of all the carnuabas I have.
The only ones that challenge it are FK1 1000p, and PB Natty's (the white one)
It. leaves the most rediculously small and tight beading of any wax I've used.
Haven't used 476 yet, but I suspect it will have similar results.
Not as self cleaning as someting like #16, but it cleans off extremely well.
It seems to acummulate light dust after application and removal. But
after a wasy, the acummulation drops a bit.
Very glossy, and wet looking; not quite as sharp in reflection as something
like KSG, or the FK1 sealants.
Apply to the wwhole car and remove seems to net the best results; seems
to be harder to do the WOWO
If you remove with a "velvet style" MF cloth, it seems to give a much more
sharper reflection. The cloth seems to give a polishing effect, unlike the plusher
towels which just remove the haze. Best of both worlds is to break up the haze
with the plush towel, then follow up with the velvet.
You can apply 2 coats in a day; allow about 30 mins. between applications,
and be sure that the intial coat-haze is removed, or you'll see it later on.
Be sure to lok at the panel from as many angles and under as much light as
possible so your sure not to have missed anything. When applied ery thin,
the haze is very hard to see as it does not really dry white. Putting on thick
coats will leave a bit more white haze, but then again, that's just more wax
that you'll waste. A little bit really does go a long way; about 4-5 pea sized
drops will prime the pad, and then just use 2-3 pea-sized drops to work in each
panel. Ad a drop or two more if you can see it is not applying to the paint.
How long should you wait if you want to top 476 with 845? Will layering the 845 over 476 compromise the durability of 476?
Thanks.
Used IW (old formula) on my car exactly 1 month ago. Washed it today for the first time in 2 weeks. Beads are still impressive. Decided to give it 1 more coat for the winter and call it quits.
Agree with USDM. Use 1-2 pea-sized droplets per panel using a MF applicator for very thin applications. Two of the better applicators for this purpose are the new Meguiar's White Gold Class and Waynestowel's White applicator pads. Removal then becomes a breeze. I'd say on par with P21S or Soveran. If applied thick then its a bear.
A great winter carnauba wax.
