My questions are;
1) what applicator do you prefer? I’ve been using a 3.5” flat waxing pad by hand (it’s for a DA) and it’s really not been a super great application experience. It really drags on the surface, which makes it take much longer to lay down a coat that id prefer.
1b) are there any tricks you have to make the applicator glide a little more smoothly that would be applicable to any foam applicator? I believe I’ve seen you mention spritzing some fk425 into the container but I can’t really if that was to soften an unusually hard tin or for a better application experience.
I`m tempted to go *against* my usual advice and suggest that you use more product. Can`t believe I`m saying that....
I never give *any* thought to what applicator I use. I just grab a "round foam wax applicator" and do it. Or I`ll do a small area using a MF towel. Or if doing the back side of wheels I`ll use cotton terry. I`ve given "what applicator" absolutely zero consideration! Lucky me, or unlucky you, or...well gee YMMV again.
I`d try better priming the applicator as the first try along lines of "use more product". Don`t go crazy just make sure the entire surface of the applicator has some FK1000P on *and IN the pores of* the foam.
Use an overlapping motion rather than straight lines.
Using some FK425 might help and I`ve never had it interfere with the FK1000P in any way.
2) the dreaded smearing and oily residue I’ve read about. This seems to be something I simply can’t avoid sometimes. Even when I applied a coat so thin on my hood that I had to go by tactile feel alone because I couldn’t see the residue I was leaving behind, coming back to buff it off later with a light I could still make out that it wasn’t giving me a clean wipe down.
I did experience a great wipe off fresh after polishing and going over the paint with an IPA solution. That was a dream to wipe off, came off very clean.[/quote]
Hmmm...trying to reconcile that with my "try using more" even though they seem incompatible...
Since going way overkill on the "prep for a clean surface" works so well, I kinda wonder whether my "don`t worry about it" just doesn`t apply to your situation. Maybe you *do* have to do all that stuff that I always skip!
FWIW, I almost always just apply FK1000P over the previous coat, or on top of some kind of AIO.
What about letting it set up longer? It oughta pass the "finger-swipe test" cleanly before it`s buffed off. Eh, I`m spoiled by my climate-controlled conditions.
Are you fogging the surface with your breath while buffing off? I *always* do that. Every time, every inch. No exceptions.
I assume you`re using your (apparently good) inspection lighting while you buff off so you can accurately gauge your progress.
I’ve also seen people say things along the lines of.. first coat doesn’t go on the smoothest, but the second coat goes on much easier. That hasn’t exactly been my experience.
Now that *really* has me scratching my head! Since it *does* layer, even if doing the solvent-action/pseudo-hologram/uh-oh thing, it`s basically "wax going on top of wax" and oughta be really smooth sailing.
I like the performance of the sealant very much. I’ve purposefully avoided using anything that would substantially alter the surface characteristics of the LSP after applying it just to see how it holds up.
I’ll usually use d156 or forever rinseless at the QD dilution as I’m drying because it’s just so easy, and it’s done pretty phenomenal so far.
I`d be very surprised if either of those messed with FK1000p in any way, but then this appears to be one thread that`s giving me some surprises!
If I can iron out the application process to be smoother/more consistent, this will be a winner in my books.
And *I* will be happier about having recommended it; I really feel that I oughta be able to help sort this out but it`s kinda challenging!
