Holy sheet: EXO v CSL v CSL w/EXO - A longevity test
so if I were to do CSL EXOv2 combo, what should I polish with underneath? I have essence but it seems like it may not be a good idea? i have Zaino AOI I could try. Or just stick with essence?
out of those two I`d go with essence for sure
if you have any non silica based polishes (non primer polishes) I`d recommend them. ZAIO is not gonna do much unless you apply it with a sanding disc, lol
but seriously don`t do that
●○●update●○●
been a while, had to go digging through my phone for these
good thing I keep records, somewhat, i guess
so at 5.6.17 I noticed mckees si02 spray was not really beading up nicely anymore so in a moment of canadian whiskey filled madness I added reload to my hood on a whim later that evening as the sun was setting.
6.13.17 next wash 2bm pblv2 soap
rinse pics
csl+exov2 side
csl middle
exov3 passenger side
6.13.17-after 2bm wash with pbl v2 shampoo, this with the reload topper I applied about a month before
6.13.17 immediately after that vid, I got a bright idea to do a decon wash on the hood with pb iron
csl+exov2
csl
exov2
6.13.17-this was after the poorboys iron removal step where i sprayed it heavily and let it dwell for 5 minutes and then wiped it in and rinsed it off and washed again with pbl shampoo
6.13.17 immediately afterwards I was testing bathe+ and pa gloss coat shampoo and I put the pa shampoo on the hood
csl+exov2
csl
exov2
6.13.17-this was after the pa gloss coat shampoo was used on the hood
●next wash 7.29.17 2bm pb sss
7.29.17- 2bm wash pb sss, pa gloss coat shampoo still seems to be helping
im thinking of doing pa cosmic spritz or high gloss on the hood and passenger side coatings since the truck is in the garage as I get ready to play with some of the drivers side
Have you still got this on the hood?
I have read about if you do treat the coatings with carpro Spotless or something like that. You can revive the coating a bit. And maybe ad a decon wash with a tar remover also and a strong diluted apc. Then do a wash with a neutral car soap to get any residue of decon away.
The thought of that with Spotless is to get the mineral deposits of the coating. Since they are hard to get of with anything else.
Really fun and intresting to read about your testing. And it`s well written and pictures and videos are great!
thanks
yes its still on three and I have, I believe, two updates to post since the last...I have just been ridiculously busy and it takes me a long time to post these. I will try to get it back to current this weekend. I have only washed my truck once in the last 2+ months.
the entire truck is covered in different coatings.. there`s a holy sheet part II that covers the hood and driver side
Great I will look that up :)
I can see this testing and write ups are time consuming. And great of you to share your foundings!
we have a great community here of folks who spend a significant amount of time sharing info with the others so I just feel I`m doing my part to contribute
The passenger side seems to be doing perfectly fine. I have never done any recon washes but have randomly topped it at the same time I topped the hood test.
I haven`t kept that close of documentation for this side/test but I do regularly check it.
Here is an update since it seems to be holding up just fine.
Quick recap:
Csl on passenger bed, with + c2v3 on part of bed
Rear pass door is 50/50 pbl vs csl
Fr pass door is all csl with half topped with 3 seperate dual layers of exov2 three hours apart
Frt drivers fender hsd exov2 x2, i added another dual layer (later added more layers)
This was applied 9.1.16
This is roughly 1year 3 months and 3 weeks
Sent from my SM-N950U using Tapatalk
Great tests and updates!
I purchased CSL+Exo4 awhile ago and never got to putting it on my car. Now cars have changed and I`m in a Civic daily temporarily.
Wonder how long they last when note opened... lol
I have had bottles last over a year unopened at room temp. Shake well and inspect for glass like shards floating which is a no go.
