Finish Kare 425
Bence said:
The Pink is bright and reflective, but over 1000P the wetness is better IMO.
Rob, I'd give the versatility nod definitely to 425. Can you use QS on plastics, laptop screens?
Absolutely.
From ClearKote's website:
An excellent color enhancer and maintainer developed for use on all paint, metal, gel coat, fiberglass, plastic surfaces, glass, tinted windows, Lexan and Plexiglas.
Used to maintain luster after polishing with Moose Wax or Vanilla Moose Wax Hand Glaze.
After washing and drying vehicle, lightly spray on Quik Shine. Using a soft towel buff to a brilliant luster. Every time Quik Shine is used the surface gets polished.
Developed for the aviation industry to be used on Lexan and Plexiglass windows.
Outside auto: Use on everything except tires.
Inside auto: Use on everything except fabric surfaces.
World's best furniture polish. Cleans windows, mirrors, microwaves, plastic counter tops and linoleum floors.
Will not leave fingerprints. Anti-static properties repels dust.
Rain sheets off windshield without tracer marks or streaks from wiper blades, when they need to be used.
Contains no Teflons, silicones, alcohol or abrasives.
Makes metallics and pearls explode out of the paint at you. Enhances the color of all paints, reds are redder, blacks are blacker, etc..
I wash my truck correctly, but I still get smearing with #425. Funny thing is it's only on the hood and roof, the sides dry fine. MF is clean, so thats not it?
what sealant or wax? maybe a temperature issue.
I might agree with that. I'm using 425 over regular Natties and under low lighting I can see where it is blotchy. Although I'm very critical of QD's clearing out on the paint properly.
It helps to buff your first before aplying 425. Particularly on horizontal surfaces. If your Carnauba (which tends to 'lump' more than acrylic) is not even the 425 may magnify this and give a blotchy appearance.
I never apply 425 without first using 146 to clean anything that may have been missed in the wash or to remove pollen/dust/sand midweek. 425's viscosity means your best bet would be to work it in a little more than a more watery qd spray. Worth the effort.
