Eagle One Wax-As-U-Dry
Why would you let it dry? You're not supposed to let any spray wax or QD dry on the car....
It refreshes the wax on the car and makes it very slick and shiny, so I don't see a need to QD unless there's streaking.
Used it todeay due to this thread, sprayed it on before i dried usisng qew, left a pretty nice finish, smoother then using just qd, and worked nicely on the wheels, with no window streaks. Good product.
I've been using this product for the past year. I used it again tonight. It's a great in between complete detail products. :)
Heh, i knew not to before hand, i just felt it with my finger lgithly to see if it came off easy, didnt, so i hit it with some QS.
I thought Carnuuba nedded to be applied ontop of either a polymer or a clean surface are there anydisadvantage of using this before a application of s100
Also what do us to dry it off does it damage or do anyting to a chammy or an absorber
Not sure I understand you statement here. Klasse is a polymer and S100 is a carnauba. WAUD works fine on top of these. I use a good microfiber to dry my vehicles (WW). This works just fine with WAUD and they wash up fine. I usually do a clay (not each time), wash polish (depending) upon need and then apply which ever wax I'm going to use. These steps take care of the WAUD when doing a full detail. I just use the WAUD as a "tune up" to a full detail.
so one last time i have sg on my car and i like to apply s100 every 1 -2 weeks can i use this waud every other day that i wash my car and still apply s100 with out stripping the waud somehow? because i know that the carnuba wond bond to everything
Man, I don't want to give you bad advice and you know the first time someone tells you it's O.K. it wont be. I don't do it exactly the way you describe. I seal or wax my vehicles monthly. I change my routine and types of chemicals frequently. I use AIO, MPPP, S100, NXT, #26, #16, Natty's, Tropi-Care, WG and a few others. I use the WAUD product at least weekly and I have never had any problem with any of these products in combination with it. As I said often I do a little more prep work than just stick another coat of wax on (not sure if this is why I don't have problems or not). I don't know if this prep actually removes the WAUD or not though I suspect it does. I have waxed without significant prep work and still have not had any problem. The only way you'll get a definitive answer to your question is to try it. For me that's half the fun, trying different combinations. The worst I can see happening is having to do a thorough detail should it not turn out the way you want it. I don't think you'll have a problem.
Is WAUD the new "IT" product at the moment, it seems like #16 has disappeared!
*grumble, grumble* more money to spend!
Although thankfully I think I can get this locally......
