David Fermani
Forza Auto Salon
Setec Astronomy said:I believe there are some difficulties in getting various panel materials, as I mentioned, to have a uniform surface finish, as compared to the old days when everything was steel and stamped in the same manner. Today you might have a variety of materials produced in a variety of ways. I believe they improved the galvanized finish, but it may not meet that Class A (?) finish that they used to get. Some of the "defects" could also be flaking of the zinc during the forming process.
Interesting. Each metal part starts out as a roll of steel, that gets stamped in a press. I've never experienced "flaking of the zinc" during the "forming process". Are you referring to the stamping of each sheetmetal part? Those parts are still e-coated & bathed to clean/cover/protect the bare surface before the vehicle goes into the paint station at the plant. Then they get refinished, so I still don't understand the "defect" part that OP is hiding over all those other layers & processes?
Setec Astronomy said:Just as a point of reference, and I know you have toured auto plants as well, but the factory setting is much different than in a body shop. In the shop if they get a panel that has a surface finish that doesn't match, they can do something about it, rework it in some manner...that just isn't going to happen on the assembly line.
Well, their different in respect to everything up to the actual coating & spraying of the panel (e-coat vs. corrosion protection/primer/sealer). Both applications still "can do something about it". Whether it's sanding for excessive OP, dust or runs, they all get done regularly in both environments. I'd have to say the OEM level is actually more critical of the final finish and how uniform it has to be. The body shop's biggest defect fear is probably color matching and straight body work (prior to refinish).
Seems like you & I always go round and round with these OP discussions...
I still plan on contacting my trainer @ Spies Hecker about the whole OP & durability thing from the past discussion.:think:
