Why is this happening..
Thanks scott, and do you agree with the whole process (as this is for wetsanding)
M105
M205
UF
I saw that you said there will be no holograms using these 3 products, but will it be picture perfect (No spider-webbing etc)?
solekeeper said:
Bump! Where's scott!? lol
Autopia has been loading pages really, really slow, kind of driving me nuts.
That process should give you spider swirl free finishes. You might have to go wool with #105 then to a foam polishing pad with it as well to get them all out and leave a finish good enough for #205 to bring to 95% and UF to take care of the rest.
What wool pad would you reccomend to use with the m105?
Would these wool pads suggested by Rasky work well to cut them out?
Megs Solo wool or W5000 wool
You might be able to use Meguiars burgandy foam cutting pads, but the SOLO pads are designed for fresh paint so that might be the best choice.
Any idea where to get them? I will be going to a spot tommorow to get another bottle of m105. And will pick up m205. And the yellow should do me well with that step right scott? Thanks!
oh, the compound isn't a problem. I already have m105 and m205.
I just need the pads.
Any online reatailers?
And you reccomend yellow for the m205, followed by the UF right?
