Setec Astronomy
Well-known member
StoicDude said:I didnt read through all the posts, but it might have been addresed.
Looking at the Meguiar's forum with the pictures, I say, the most work done was with the polish and NXT. I tried Scratch X on my black 600RR and it didnt do crap. Menzerna IP, FPII was another story.
I will try to do SCratch X on the whole bike again with a PC and see how it comes out, but I am not putting my hopes up.
I suggested to the OP that he use ScratchX because it's readily available, he only had a couple small spots, and he was working by hand. It was made for those purposes. If you are working with a PC, I'm not sure there is any reason to use ScratchX on large areas (although Meg's says you can), certainly IP/FPII would be a good choice.
As far as your comment about the polish (presuming referring to #7) and NXT doing the most to remove the etch, if that is the case, they just filled/hid it...which is sometimes the only option you have if it is really bad. Since the OP was able to remove them with the ScratchX, they should be gone for good (as long as he didn't take off too much clear, which I doubt by hand).
