transamfan
I do restoration paint jobs in my spare time as a hobby and a way to make extra money. I get good results when I cut and buff but I'm looking to perfect my buffing skills because I believe it will help me take my work to the next level. Most of the discussion on this forum is aimed at paint correction of factory paint that has been neglected over time which is very different from the paint that I work on. When it's all said and done I will have 5-6 coats of clear on the car and usually wetsand with 1500 then 3000 before buffing, and I have been using Menzerna compounds/polishes with Lake Country CCS pads. The clear I use is very soft and buffs easily.
Questions:
I usually start my sanding with 1500 on a DA. Sometimes I have a little more orange peel in some areas vs others so I have to spend more time sanding there to get it out. It seems like in these spots I end up with a bit of a ripple effect when looking at reflections once I get it all polished up. I assume this is because although the panel and paint are flat, the clear is not due to the sanding with the DA. I am thinking about starting my sanding on this next car with 1000 on a block to get all the orange peel out and then moving to the DA. Will I be ok to go with 1500 to get the 1000 scratches out you think, or maybe 1200? Maybe 1000 to start with is too much? By the way, I plan to use Megs Unigrit 1000 and then I'm gonna try the Norton Dry Ice system on the DA since I read a good post about it here recently.
Once I get the clear flat with the sanding, I'm ready to bring the shine back. The car I have in the shop right now is black and I'm looking to get the best gloss/depth possible. How much of this is going to be the products I use vs just having good technique? If I get the clear perfectly flat with the sanding, then remove all the sanding by compounding and then remove any defects of compounding with polish, the surface of the clear should be perfect and defect free, but can getting it defect free with one group of products vs another make a difference in the final appearance? This is the real questions I'm hoping to get answered because I've only used Menzerna's stuff and I've always wondered if I'm missing out on something.
Questions:
