O-kay.
Some diagrams that may help, and more discussion.
This one compares a long block to a short and long stroke sander.
If you want to see a clearer shot of it, I have a pdf version on my site:
Machine Stroke- How It Affects Sanding and Polishing Performance
The diagram is on page 9.
I don't usually link it because it is a site that sells stuff.
MODS- if I am not supposed to put a link, feel free to remove it.
The type of backing material a sheet or disc features can also affect leveling.
To be clear, the
backing is the piece of material that the sanding media is attached
to.
Several types of backing materials are used to make backings for discs, and the type of material is a BIG deal in terms of how the disc performs.
In general... if we have two discs featuring identical backings, except one has a backing that is thicker than the other,
and we are using a backing plate that is soft and cushiony:
The disc with the
thinner backing will
level to a lower degree, but contour to a
higher degree.
The disc with the
thicker backing will
level to a higher degree, but contour to a
lesser degree.
The harder the backing plate, the less of an issue backing thickness becomes.
Now, here's where things get a bit tricky.
Some discs feature a piece of foam placed between the backing material and the attachment material. Most times, the foam increases contourability at the expense of leveling ability. But really, the characteristics of the sanding disc's backing determines how much an effect the foam has on sanding.
Super thick and stiff backing?
The disc may flex well, and follow curves and complex panel shapes, but it may not contour to every nuance of the surface, such as orange peel.
Super thin and pliable backing?
The disc may follow every nuance of the surface and follow curves and complex panel shapes, but may not level the paint surface.
What if machine speed is maximized?
The effects of foam may be minimized.
Check out these discs featuring foam:
Mirka Abralon:
Tremendous contouring ability, wide range of grades. These are a kick to use, can be used at high or low speed. for me, low speed is better because the sanding pattern is smooth, and the abrasive particles stay attached to the disc longer. Higher speed offer a tiny bit more leveling, and can keep the disc cleaner, as rotational forces fling debris from the disc more readily than slow speeds.
Magnified shot:
Mirka Abranet Soft:
Excellent contouring ability at low speed, fantastic leveling ability at high speed. Compared to discs that use paper or film backings, the net material allows water to pass through (like treads on a tire. So, you can sand with water, use higher speed if desired, yet hydroplaning is not an issue.
Magnified shots:
Meguiar's Unigrit 3000 Foam Finishing Disc:
Unmatched finishing capability... it's like having thousands of super soft abrasive squeegees gliding across the paint! Virtually no ability to level, but at this point, you should be refining the surface to shorten buffing time rather than worrying about additional leveling.
About film or paper backed discs:
Film or paper backed discs generally feature maximum leveling potential, but when used with water, they tend to float or hydroplane rather easily. This leads to inconsistent sanding results, as some areas may be sanded perfectly while others are barely affected by the sanding disc. Once the water is displaced, the disc, oftentimes spinning at a rapid clip (due to a lack of frictional resistance) makes a crash landing atop the paint surface. This leads to pig-tailing, gouging, or scouring.
I hope this info didn't miss the mark, or stray too far from it.
I find this all to be so interesting, and there are lots of things to consider.
The biggest thing that limits our ability to use hard-backed backing plates has to do with user technique. If while sanding we happen to tilt the machine even slightly off kilter, the edge of the disc can dig into the paint. This can create some pretty dastardly sanding marks, especially if we're using coarse grades of discs. That's why most backing plates made for sanding discs tend to be soft and pliable.
Now... think you're pretty good at handling a machine?
Why not make your own backing plate/interface pad combo?
Get a stiff backing plate, and attach a foam interface pad to it. Then, get ahold of a piece of Plexiglas, cut it to the size of the disc, and attach Velcro® hook material to both sides. Slap on your disc of choice, and get to sanding!
The foam interface would help to minimize user-applied tilt variances, so if you happened to get the machine a bit off kilter, the interface would compensate for it. This setup would be ideal for flat panels, but terrible for curved or complex shaped panels.
That's all I've got! For now...
