imported_Detailing Technology
Jakerooni said:I also don't get how it takes 3 hours to wheel out the paint but only 60 seconds to wetsand it?
How are you taking off the wheels? 4 way lug wrench or impact? could shave off some minutes there as well if your using anything but the air compressor.
Can't really comment on the products used because I've never used them. But It might be worth the while to check into other products that have less cure times. If you can find any in the same quality range of the products you use.
I like the leaf blower, its a little more quiet in the driveway than the shrill of a blow gun on a Saturday morning, I do these at my house.
I "spot" wet sand if necessary, not an entire panel. If there is a deep scratch or mark that will benefit forma sanding, I hit it.
I use and impact gun on some, the Lamborghini's and Ferraris get a hand twist with a star. I do not want to buy one of those wheels if I slip and scuff it.
I think a lot of people get hung up on different chemicals for different paint manufacturers. I try to streamline the process by using 1 abrasive manufacturer for all paints. I have been most satusfied with 3m until I tried Optimum, now its Menzerna as a complete abrasives line. I have all of the Menzerna abrasive products, 106ff and SIP are just staples to get rolling. You can find a lot of flexibility with products when you try different pads to get going with SIP or 106ff. I recently used Zaino Z-PC just to mix it up, not worth it to me. Results are results as long as you get there. Not all cars need such aggressive resurfacing, the previously mentioned schedule just outlines a worst case scenario. 50% of my work is completed with a few passes of a SIP/106ff mix and a few different pads on the Makita to get all of the depper marks out.
Most of these cars are trophys, they all arrive in decent shape. The only cars I see that need SIP have been tortured by a tunnel wash or a local hand wash guy at their office park. I also recommend to my clients not to come to me more than 1 time per year.
I recently got into installing the clear film bras from 3M. My first will be an M5 on the weekend of the Super Bowl. This is also completely outsourced, the dealer quoted $995, the installer quoted me $400, I quoted the end user $650. The installer agreed to come to my house and do the work there. I went so far as to have the installer come by on Monday to see my garage so I dont get any lip from him on Saturday when I have the customers car here.
