David Fermani said:
All this work:
In this amount of time:
For this amount of profit (?)
I have a few questions after reading through your comments:
Are you doing the detailing yourself on these high end jobs? (I'm confused why you posted your labor costs as if you were paying them out?)
If you are doing it yourself, I can't see how this extent of repair is being done in this time frame?
If you're not, aren't you opening yourself up to alot of liability/exposure for $65 profit?
I am paying it out, I'm an S-Corp.
The $600 is for me, I have to give myself a pay-check.
I am rarely on time. I document $100.00 hr and I bill each car at 6 hrs flat to justify the $700 fee should I be asked. I am typically finishing at 7, 7.5 total time, but have been done in 6. I have a pre-defined process and a plan and follow it to the minute. My last 2 clean-ups were 7.7 hours of labor. I am operating at a loss at that point, its used as a metric to track success or failure.
A few things I do and do not do:
1. I do not use a digital micrometer to measure paint thickness. In 20 years of using a rotary I have never seen anyone burn through the middle of a panel, edges get ripped plenty, middle of a panel, never.
2. I do not clay obsessively. I clay the hood, roof, and trunk while washing. If I cant get the finish smooth with a wool pad and SIP, should it be so nasty, I will know this before I price the job and price accordingly. Haven't seen one yet.
3. I combine 3 initial cleaning/prep stepsinto 1 process. I put the car on jack stands, should I be so lucky they fit under the car and then remove the wheels. Otherwise I lose time doing a laft to right car wash with my low height floor jack. I pressure wash the car, engine, clay, clean the wells, wheels at this time. I put the wheels back on, roll it into the garage. I dry the car with a leaf blower then touch up with the air compressor in the garage. I also blow the interior out with my compressor while its outside in the driveway. Saves on vacuum time. Total time is 1.5 hours.
4. I do the interior first. This shields me from contaminating the exterior surfaces with dressings and window cleaner. It also prevents me from rubbing a Desidero or a vacuum home against a freshly polished surface. I dress the tires, wells, and engine at this time. Total time is 45 minutes.
5. I use 2 Makita rotary polishers. The first rotary has a 6" Edge pad, the second has 2.75" backing plate for use with 4" Lake Country pads in tight spots. SIP used with a rotary, 106ff is also used with a rotary. Should the vehicle require some touching up or some massaging with a PC, I break it out. I have however incorporated the Porter Cable into a fine finishing process on well kept cars. A typical car requires 3 hours to run over the panels. The R63 I did took 4, its huge. Should I need to sand out a scratch, add 60 seconds per panel. I have a few sheets of 2000 soaking before I start.
6. Zaino application. Put it on the entire car including the wheels, go eat lunch. Total time 15 minutes application, 45 minutes dry time. TOTAL 1h.
7. Zaino application 2. Put it on the entire car, walk around start final cleaning or all egdge, tim, exhaust, trim dressing, second tire dressing. Total time 1hour.
8. Souveran spit shine wax appication. Painted surfaces only, total time 30 minutes. Wipe-on Wipe-off
9.. My garage is heated to 70 dgrees in the winter via kerosene heater. Im not cold, the car isnt cold.
As you can read, i need to trim some time to make the $100 hour goal. I am continually refining the process. I also have all chemicals repackaged, laid out, and clearly marked in hand held sizes to reduce time searching for the right thing. In the driveway, I have a hand cart, in the garage I have a rolling seat I sit on and everything stay under me. The halogens are set up ahead of time, 1 in front, 1 in back. I move them from side to side as I polish around the car from top down.
I dont have many pictures of the configuration when I work, but here are a few I found.
Some items that stay with me in the seat
Brought into the driveway
In garage, larger dose bottles.
After each job, I wash every used microfiber and refill all of the bottles. This eliminates wasted start up time for the next weekend. I also keep enough microfibers, polisheng pads, and product on hard t complete a dozen cars. I never want for anything.
