pharmboyrx said:My dad says it shakes the Earth when those cars take off.
You feel it all through your body. I used to go to the Motorplex in the fall for the national event there. Always had a blast.
MotorCity said:The ride at Cedar Point is AWESOME!!!
Highly recomended
pharmboyrx said:I remember one time on ESPN they had a cross section of a top fuel engine. It had the actual injectors over cylinders that were cut in half and covered in glass so you could get an idea of the volume of fuel that runs through the engine.
Just at idle it was an incredible amount. When they turned it up to show what it was like at full load it was like a freaking fire hose. I would believe they ran almost at hydraulic lock. I was amazed that the engine could still be running with that much fluid running through it.
I've always wanted to go to a top fuel race. My dad says it shakes the Earth when those cars take off.
EisenHulk said:Scott, from Northern KY, you're looking at about 5 1/2 hours to get to the park.
DaGonz said:At the Fitchburg Airport' s annuall Autumn AirFest, there was a "race" between Les Shockley's "Shockwave" ( a 1957 Chevy pickup powered by two jet engines!) vs. two of the aerobatic aircraft in the show. The aircraft approached the runway about 100 feet off the deck at 300 MPH, Shockwave took off from a standing start and blew right by under them! That was impressive!
