First, let me say that I am not affiliated with the company that manufactures this product in any way. I first saw this system a couple of years ago at a car show and have been wanting one ever since. I have family in the city where they are made and serviced, so this weekend on a visit I took the plunge. It turns out it was worth it....
This little guy is called the Invisible Chamois.
The system consists of the main filter, the input water line and the exit water line and sprayer. I also got a total dissolved solids meter. It will tell you, in PPM, the number of dissolved solids in your water.
Here is the meter reading my tap water:
This filter produces deionized water that is free of all mineral deposits. The manufacture calls it ultra pure water, and it is. We tested tap water in their building (375 PPM), reverse osmosis water (5 PPM), and DI water from this unit (0 PPM). The filter contains a plastic resin that filters the water via ion exchange producing pure clean water. Over time the resin will become unable to filter the water as effectively, and the manufacture will regenerate the unit for a fee and send it back out to you. They recommend sending the unit in when the meter reads 10 PPM. If you don't use the meter, you just send it in when the water begins to spot.
There are three different sized units, mine is the medium. Washing once per week and using five gallons as a final spot free rinse, this size unit is rated for 54 washes. This number will vary depending on the hardness of your water, and I believe that number was based on the 375 PPM rating of their city water. Mine should last longer because my water is not as hard.
So how well does it work?
Here is the filtered water out of the unit:
After washing the truck normally, I did a final rinse with the DI water. Here you can see it drying on the bed cover.
Here is a dry section of the truck.
I am extremely happy with this purchase. I no longer have to worry about water running from the door handle, mirror, or emblems and spotting the paint. There is no doubt this system is an investment, but after the initial cost, it works out to about 1.50 per use. That won't be bad over the long haul. I remember the days of spending eight bucks at the car wash! :xyxthumbs
