imported_alan81
NEED YOUR OPINION. I found this short article at a website. This article gives me a really bad impression on polymer based wax. I really need your opinion to answer two questions:
- is polymer based wax really that bad ????
- which is better, carnauba based wax or polymer ????
Thanks.
Here is the article:
Acrylics and polymers are essentially plastics. Plastics are a man-made substance made from petroleum. Plastics have their place, but we do not feel it should be on your car's finish.
When you use a natural carnauba wax, the paint is allowed to expand and contract naturally; the carnauba does not impede this process. However, plastics are a molecular "chain" that interlocks with the molecular "chains" next to them, so that no individual "chain" can move without all of the "chains" moving together. Because of this, plastics do not allow the paint to naturally expand and contract and can cause premature paint failure. This failure will show up in the form of cracked paint, sometimes also called "spider webbing" because of its look.
One last problem with plastic-based products is that they layer and build. With a carnauba-based product the wax does not build up in layers; each new application leaves a constant amount of wax on the car, regardless of how many times you apply it. With plastics, one layer builds on top of the existing layer; this can cause discoloration or yellowing of your car's finish. To prevent this, most manufacturers of plastic-based coatings also sell a "cleaning" kit to remove the old coating. This "cleaning" kit is usually nothing more than a polish or solvent to remove the old plastic before applying more plastic. :bounce
Thanks.
