klumzypinoy said:Hmm...he said he's using exceldetail's 6 inch backing plate, but there's no 6 inch plate for the PC on that site...
Welcome to Exceldetail.com!
BigAl3 said:
Setec Astronomy said:What else impresses me is that unlike some other hand-polishing professional members, you embrace change...with machines, products...and of course you take the time to answer all questions and help the newbs.
JayC said:I really like having the handle.. but its unusable on high speeds. Im going to have to come up with something to dampen the vibrations.
Alfisti said:Just stop using the handle...you'll find your machine will easier to use and control. Also, less vibrations. :xyxthumbs
cgage said:The vibrations are from the pads. When I use 6" or larger the UDM becomes a bear. The 5" CCS are perfectly balanced with almost no vibrations.
Also, I prefer using the UDM without the handle.
Ruttrow said:I was looking at the 5-1/4 pads from Lake County. Before I spend MORE money does anyone know why if that is indeed the case why most resellers package with 6" pads? If what cgage is saying is correct why not supply with what appears to be a less expensive pad. Just because of size that is. Thanks.
