mikenap
Thanks guys. I'm aware about the light pressure with the surbufs, but how come you can use heavy pressure with the Meg's MF pads? Wouldn't you not want the microfibers to flatten out? Or, does this not apply to MF pads?
Not really sure of the reason, but I think it might have something to do with the firmness of the foam used in the MF cutting pad vs the spongy foam on a Surbuf? Also, the Megs MF fibers are a bit longer and thicker than the Surbuf microfingers, so the compound could stick to the MF better and still work even when flat. I'm really just guessing on the reason, but you're right that the MF pads perform better under pressure than the Surbufs.
On another note, I know you're a Flex guy. Are you using Surbufs and the MF system with the Flex or a standard DA?
