Eliot Ness said:
You can order a good set of pads and backing plate from Excel Detail. Start with the kit that CutNAction has a link to:
http://www.prestostore.com/cgi-bin/store.pl?ref=exceldetail&ct=&pd=97914&pg=14145
Then add something like two green pads (polishing), a yellow pad (med cut), and an orange (light cut/polishing) pad. All seven pads and backing plate will only run about $60, but youâ€â„¢ll have a nice range of pads to use and an extra one of most if you switch to a different product during a detail. Between the kit and the extra pads you'll have:
1- Yellow Medium Cutting pad
1- Orange (light cut/polish) pad
2- Green polish pads
2- Blue Light Polishing pads
1- Gray finishing pads
1- 5" Backing Plate
You can adjust the number of pads depending of the products you're going to use, but you won't beat $60 for a pad kit like that!
BTW, CutNAction has provided some good links!
I think I'm going with something similar to this.
1- Black Finishing Pad
2- Blue Light Polishing Pads
1- Green Light Cut Pad
1- Orange Pad
1- Yellow Medium Cut Pad
Another question, are pad colors the same from company to company? Like, will Yellow always be a medium cut pad, or a cutting pad at least?
For process, something like:
1Z PP with green pad to start, if that doesnt work move to the UPP, if that doesn't work then move to a yellow pad? More or less working up in abrasiveness, so not to get any overkill.
For applying AIO, I should use something like a blue or black pad? And then I would apply SG by hand, for the thin coats.
That all sound pretty good, in theory at least? Think I should order more of any pad, or is that enough since I only have a few products?
Also, does anyone have a cupon code or anything that I could use and save a couple bucks? The setup I have listed here is $65
