SSR2.5 ...proper amount to use
looks like we have lost the pictures in the transition from .com to .org
ok i put them back but they are all in the first post:)
I'm new and just recently started using a PC with SSR 2.5 on a white pad. I have been using distilled water, misted on the pad. I did this originally trying to get the product to spread through the pad and to use less product.
Sometimes when I turn the PC up to 5+ I get some pad shimmy/flap, as a previous poster mentioned. Is this because I have to pad too damp?
Also, is it ok to work 2.5 to the point that it is virtually gone from the surface?
I usually have to wipe it off with a mf.
Also, I don't get dusting at any point so long as I don't let it dry before I take it off.
Thanks, sorry for the long post.
Welcome, and that's a relatively short post.
SSR products go with a dry pad. I made the same mistake at first since I was used to compounds. Keep the pad as dry as possible.
And perhaps use a little less product and work it in like Steve said 4-5 mins/panel. It's a long wait, but it is worth it.
Ferrarislave said:
Would you recommend the same amount of product on a rotary? Also, do you recommend keeping the pad dry?
yes you keep the pad dry and I would use a bit more product as the rotary creates a bit more heat and friction.
Thanks. I have the entire SSR line, but have never really used it. I tried it with the rotary a few times and it took forever to break down, but I wet the pad a lot. I was too used to Menzerna products. I am going to take another stab with SSR2.5 this weekend see how it goes! I keep coming back to the products, cause they smell so good!
I worked on my car (black) for the first time today with ssr2.5 on SFX pads (4" and 6"). I got a TON of dust all over and I couldn't see the polish on the paint (well, there was this hazy looking stuff that disappeared and reappeared sometimes) after about a minute of working it on speed 6 (spread on speed 2-3).
I started off by spritzing with either sonus acryllic spritz or detailing spritz and then I primed with an X that used less than amount shown in this thread. Then I used 4 dime-sized dots after that when I needed more.
P.S. Is it bad to leave the dust on the car for an extended period of time? (outside or inside)
no,but you should get it off as soon as you are done polishing and here's your answer to the dust
here's your answer
What's the best way to get the dust off after it's been on there for a while. I'm eventually going to clay it and that'll probably work, but it's stuck in some small areas that are hard to get to.
I noticed the first time I used the UDM I primed the pad with a spray on that came with my kit. LOTS of dust! This afternoon using the SSr2.5 I used a DRY pad and got none. Learning curve for me...
yes the SSR's are not full of oils like some other polishes so adding water to the mix will only dry them out and cause dust ;)
i love PB SSR 2.5 and ssr 1 now ive bought black hole so need to try that but i keep coming back to SSR
I'd start with an LC white with the SSR 2.5 and LC gray with the SSR 1. This combo has always worked well for me.
