SSR2.5 ...proper amount to use
lonewolf0420 said:
so let me get this straight when your doing lets say half the hood or one door you work the area has a whole not one section of the door at a time or one section of the half of the hood at a time?
Yes, you work the whole area that you covered, going over it as many times as needed to work the product thoroughly.
You buff till the product is virtually clear? You did two doors with one one ring of product on the pad?
Basically, spread it as far as it'll go until you can barely see it on the surface.
Then turn up the PC to 5-5.5 and buff until it disappears.
That doesn't seem like enough. Then again what do I know My SSR arrives today and my pads arrive tomorrow.
there's a learning curve to any product, and if you want to get the results that are possible, then you will have to practice a bit.:)
lonewolf0420 said:
So you ran the PC at speed 5, what about when I follow-up with a coat of SSR1? should I use the same speed setting?
yes, all polishes need to worked at a good speed to get their full effectiveness.
Steve, i feel like such a noob asking this question. When you say thats the amount you used for all those different panels was that the total amount in that one pic that did basically the whole car? or everytime you applied that's how much you used?
No problem, that was each time I applied product to the pad:)
Steve, the dusting you show in the pics is moderate compared with a lot of commercial cut polishes, and similar to other compounds I've used. I tape off big jobs since I'm using a rotary, so I also put some damp clothes over the place where dust is most annoying--the water collection area where the windeshild wipers are.
I just ordered my first SSR2.5&1, will come in the next week or so. I'm using a DeWalt rotary. I typically apply cut polish or compounds at 1000rpm, and ramp up 400rpm each pass until about 2200rpm. I rarely go to 2600 or 3000 rpm unless it is a large flat panel and heavy oxidization. If the pad has lots of product I sometimes spritz water for another pass.
Is this a good way of doing things for your product? I'm going to hit my 2001 GMC Jimmy, metallic blue, with webbing and a couple of imperfections.
Poorboy said:
:lol:
Patrick after the first panel I couldn't find any dust to photograph either,
but I was trying to figure out where some people were getting all this dust from :ermm: ...I worked the SSR2.5 in the sun on a 80+ degree day and only found a little kick off even after working it when it looked like there was no product even left to polish with.
I also tried using too much product and that is where I found more kick off but no dust. I'm thinking that anyone who is getting dust is getting a build-up on their pads, since my pad showed virtually no sign of SSR2.5 left when I had finished each pass.
The mystery continues :detective
More testing to come :cheers:
Like Patrick I get no dusting but I do clean my pads after doing a few panels . I use the Foam Pad Brush Dwayne sells ,it works great at getting all the build up off your foam pads, works with both the PC and rotary . This may help some of you out.
So I finally tried the 2.5. Not bad cutting power, and I only got moderate dusting.
For the first time, though, I got swirl marks--halos or holograms from the buffing pad. I followed with a lighter pad and then a lighter pad and lighter polish and then AIO. They were mostly gone but evident here and there.
I've never gotten this with other cut polishes and compounds. I used a DW849+yellow edge pad and worked the product till gone.
The only thing I did different was not use mists of water like Steve said (dry pad).
What did I miss?
What was your follow up polish ?
I generally go with either SSR 2.0 or Optimum on dark colors, sometimes on light colors, I dont need to....
What did I miss?
Did you prime the pad with product? What speed did you use it at? ...and check your pad for wear as well as product build-up...
I followed your pics at the beginning of the thread (the circle). Pad was clean to begin, only used once before, and used a nylon brush to keep it clean. I used the hood to start.
Steve
Would you recommend the same amount of product for the other SSR's? I would guess if you used the same amount of product for the other SSR's, the only difference would be the amount of time used to work each product fully.
yes the same amount of product for all SSR's..time will always very due to conditions and variables of the temperature, surface condition, pad used.
I prefer the Lake Country VC (variable contact) pads with my SSR's. I've used a few other brands and results did vary among them. :confused:
Interesting. I have never had any problem with dusting with SSR 2.5 (or any other SSR for that matter). Of course, I use virtually the exact amount shown in the pics, and the same method of applying. I also use the Lake Country VC pads. Excellent results every time.
After reading through this thread, I am sorely disappointed. Oh, don't get me wrong, Steve's OP was spot-on and VERY informative.
However, I want to see how his granddad's car turned out!!!!!! :exclaim:
LOL,
Charles
LOL,
Charles
Sorry Charles, I'm not a big picture person, I thought the few candid shots were what I was after for the thread.
My grandfather was quite please to see his car looking so good and he did give me a nice tip :hug: :yes:
I've wondered that too.
I've used the better part of a bottle with a rotary, mostly with a wool pad or medium foam cutting pad. I used the same basic principles, except holding the pad up a little on first blush to avoid sling. I start at 1000rpm for spreading the product, then on flat panels I bump to 1800 then to 2200. On side panels I do 1000-1400-1800.
The product still takes time to work in, and needs the heat to break it down. I put mf towels on the bottom of the window to collect dust (hard to clean area).
I get no haze left over. With a foam pad, not much dusting at all, much less than my commercial cut polish. With a wool pad I still get dusting, enough that it needs a full wipe down between steps.
It is not like cut polishes and compounds in that it doesn't use water to break it down, but heat along. That is helpful for me when doing a quick job like scratch repair. It is not as quick at bringing back wet(color)-sanding marks, but because the dust content is lower, on spot jobs I prefer it.
But the car must be dry. Water clogs the pad and doesn't help the product. It can causing bouncing with a foam pad at lower rpm, or with a wool pad it leaves little speckled residue (any polish can do this if it gets wet then heated too quickly, but 2.5 especially does it). Not too hard to remove the speckling, but it means putting the 2.5 onto the speckled area and hitting the panel again.
So far I haven't had significant marring with 2.5 and any pad, despite some serious work. And one step was always enough to follow it, either SSR1, a PB polish, a commercial polish, or the Farecla G10 I use sometimes.
Hope that helps, though Steve may have more.
For some reason the pictures don't show up. Can you describe how much I should use since I don't have pics to base on?
