Was sanding out where someone had keyed my car, and got a little over eager with the sandpaper...
Is there ANYTHING I can do to minimize this damage short of taking it to a body shop??
It's a ten year old car, Taffeta White paint color... Would it be possible at all to lightly spray on some color matched paint and add a new clear coat over that?
How good do you want it to look?
It's not a show car or anything. Just trying to get it decent looking to the average person.
You can try that, and some highly skilled professionals can do an okay job with spot repair, but in most cases (with a highly skilled professional) the spot is still extremely noticeable.
If you want to give it a shot, lightly sand the area with 600 grit (and feather outward from the mark. Clean the area with pre-paint body solvent and mask off all of your trim and adjacent panels.
Start with a light misting of a light colored primer, maybe add a second coat. Mist a couple of light coats of the base color, doing your best to match the color. (Feather this coat out slightly more than the primer. Finally apply 2 light coats of clear and a final 'wet coat' again on an area slightly larger then the base coat. Let it dry/cure for a couple of days and clean it up with a light sanding (2k-3k grit) and polish.
It probably isn't going to look that great (being honest) but it might look better than what you have now.
I think your right , let a pro do it....Especially that area is highly noticable to start with.Hmm. Maybe I should just let a pro do it... Seems like a lot of trouble to go through in order to only get a semi-ok result if I get lucky.![]()
If it is indeed Honda's Taffeta White, that's a single stage paint. Not sure if that matters as far as the current condition, but I would imagine that a repaint with clear will leave it looking distinctly different from the rest of the car.
