Range Rover Sport - 2 day correction detail *long*
Great job! RR came out beautiful! I love RR so much, I would defenetely consider purchasing one. One question, why did it take you 2 1/2 hours on wheels/wheel wells? Did you remove the wheels to clean them (that could explain)? If it's caked on brake dust you should use Sonax Full Effect wheel cleaner, which will actually clean, and it doesn't take all that long...just wondering...
That was a ballpark number... But I cleaned them once with P21S Wheel Gel (hadn't heard of Sonax when I did this car, nor have I tried it), but needed a second cleaning with soaking more gel and then a lot of scrubbing. The tires also had heavy buildup of old wheel gel and those Continental tires have about a billion little crevices on the sidewall that took forever to get clean.
that explains a lot. Sonax is basically neautrilized acid, it cleans as well as Megs WB (which you can use, but be careful and remember to neautrilize acid with alcaline based cleaner), yet is as safe as P21S. P21S on baked on dust=lots of work...I love Sonax Full Effect so much, I hardly ever use P21S...even though Sonax smells like rotten eggs (my farts smell the same, so I'm used to it...)
Is Sonax FE more cost effective than P21S?
PAC sells P21S Gel for $14.99 for 500ml. The Sonax FE foes for $19.99 for 16.9 oz. IMHO, the Sonax is absolutely worth the extra coin.
Why is that? Other than 1 or 2 vehicles, I've never had issue with P21S performance... What makes the Sonax so much better? Do you use less or something?
