Leadfootluke
I have applied it on certain plastics and by waiting a *touch* too long, it stained. I just wiped it once more with 845 and it dissappeared, but you do need to use the Wipe on, wipe off approach.
KneeDragr said:Wow, Ive been using FK1000p on my daily driver but you need to avoid trim at all costs with that stuff. This is probably the best reason in my book to switch to 845, I can protect the trim at the same time. If I could get 3 months of trim and paint protection out of this stuff I would never use trim darkening products after washing again.
Anyone know if the Collonite paste waxes offer similar trim protection? Do any of them outperform 845 in terms of longevity? I usually prefer paste waxes, but If the 845 is the way to go it will be in my next order.
Rob4092xx said:Guys.....the only thing worth a while is Gtechniq C4. I put it on the trim of my wife's Ford Expedition and WOW!
I purchased a second bottle for my Hummer and all I can say is WOW!
This stuff is outrageously expensive but it sure makes your trim look like new again. I researched the crap out of it before buying and everyone says they get 1 to 2 years out of it.
I can see why after applying it as it leaves a hardened type surface once it dries. I have since washed both my Expedition and Hummer several times since application and nothing washed off! No greasey mess at all.
KneeDragr said:Wow, Ive been using FK1000p on my daily driver but you need to avoid trim at all costs with that stuff....Anyone know if the Collonite paste waxes offer similar trim protection? Do any of them outperform 845 in terms of longevity? I usually prefer paste waxes, but If the 845 is the way to go it will be in my next order.
umi000 said:The order of durability (according to Collinite), from most durable to least, is 476, 915, 845. However, I don't know if the paste ones would stain trim (I've only used 845). Accumulator would probably know - I recall he mentioned using 845 before topping with 476, which if I remember keeps the 476 from staining?
Accumulator said:Leadfootluke- Glad it's working so well, and that you're updating. Reading about your experience might help convince more people to try it.
You're not even using a leaves-stuff-behind QD on it, are you?
Leadfootluke said:...And just for fun, on the driver's side mirror, I used Klasse AIO on the plastic to clean it, and then I laid down a tape line did 845 on the inside this time, and 476 on the outside....
