bert31 said:Can you use a UDM for carpets and a 4" spot pad with a UDM?
Yes. Please see my answer above.
:ignoreZoranC said:Exactly my point. If you don't beg to buy (like everybody does not because when one wants to buy something easily available around he doesn't need to beg an existing owner to buy from hi, he just goes and gets it anywhere) then why you would wonder whether he begged to buy?
:hm
rkf76 said::ignore
wow, this is some good coffee
FMINUS said:Where can I get the Festool for the lowest price?
FMINUS said:Does the festool use the same backing plates as the PC?
FMINUS said:How does the weight compare to the PC?
FMINUS said:$440 USD for the DA? what the heck?
FMINUS said:THat would be awesome! so $440 bucks???????
FMINUS said:Would the velcro pads still work with them? How many backing plates does the festool come with?
ZoranC said:UDM has exact same thread size as PC and Cyclo do so Cyclo carpet brushes (and all other "backing plates" meant for PC) will work with UDM.
bert31 said:So basically, anything backing plates or pads that will fit on a PC will fit on a UDM? Or to state in another way, anything you can do with a PC you will be able to do with a UDM?
jmarm3 said:So, are we saying that the festool is the ultimate detail machine... would you dry sand with it instead of wet sanding ..... and is it a random orbital and a rotary all in one ... im not getting this>Im very interested but im not understanding its capabilities. I was thinking of getting the cyclo and possibly the makita rotary 9927c, but if this thing does the job of both im going with it.
tod071 said:jmarm3, The Festool will not replace both DA and Rotary. It is in between. It will replace the DA and add rotary capabilities up to 600rpm, which is good for some correcting. But most people use it as high as 1500rpm, and therefore, you'll still need the Makita.
