Are you talking about CarPro Eraser? I'll look into the ones you mentioned,thank you.
So basically, after polishing/compounding *maybe* use <span>AkraClean or CarPro Eraser to get rid of the oils. But if I'm using a non-diminishing compound, use the M34 as it is better at removing the abrasives, then *maybe* follow that with <span style="color:rgb(40,40,40);font-family:'helvetica neue', helvetica, arial, sans-serif;">AkraClean or CarPro to remove the oils.
<span>As far as the *maybe's* are concerned:
<p style="margin-left:40px;"><span>The impression that I got was not that the oils needed to be removed for the sake of removing oils or because they are bad for the LSP, but because it allows one to better check the quality of their work by making sure the surface is all that they are seeing (no defects missed because they're hidden/filled). So yes, I would agree that it is a maybe. I'm not going to want to be quite that detailed every single time. I may just have a minor imperfection I'm working out, in which case it's not necessary.
