Paint Leveling with HD UNO
tdekany said:
It is different from everything I have ever used
Well, that's saying something, huh? I've never been all that intrigued by the "single product, different pads" approach, but this does pique my interest.
OK, sort of thread jack. I promise I will read the entire thing later. I just got some UNO, of course had to try it immediately on a car I was working on. Used it via DA on an MF cutting disc, nice cut...similar finish to D300 I found, little more cut. Then went to an orange LC flat pad, cleaned up the micromarring nicely but left some finer marring behind. Went to a white LC, same thing....still some marring, blue, same, black, same. Which trick am I missing? I am sure there is one? :D
Editting my own post. Heed my warning new UNO users, it is easy to use too much. I was using way too much, basically it wasn't do anything and just kept leaving the same finish. I switched to another black flat lc pad, two little dots, whamo, perfect finish. Not bad so far. I like messing with new stuff, it's definitely a different working method than what I am used to with 105/205/8rd etc tho.
tdekany said:
Nothing wrong with 205, but next time use UNO for all steps. You will like it.
So are you saying for the noob here that UNO is the type that will finish differently with different Pads?
IE Orange/MF cutting pad with Uno will be very aggressive but if I step it down to say a white pad I would still get cutting action but a better finish?
Start with Meguiar's MF Cutting Pad with Uno > than finish with Meguiar's MF Finishing Pad with Uno?
I tried my first attempt with Uno with an orange LC CCS pad yesterday on a 2010 Civic hood, and I am pretty sure I used too much. I will give it another shot this weekend and see if I can get some better results as it wasn't cutting near as much as I thought it should.
06 Black Yukon - Orange pad and two drops of UNO did wonders. IPA wipedown and it left very little mar, just a very slight mar. White pad cleaned it up nicely and then I jeweled it to a brilliant shine.
so is it recommended to use different cutting and finishing pads with UNO instead of just buying the UNOPAD?
I just got my GG machine in and I've never polished anything. UNO on an UNOPAD sounded like a great way to really simplify the polishing process. Is that not the preferred method anymore? I'm looking for 80-90% correction that finishes out perfectly.
Not sure what you mean my "UNOPAD"(singular), because they offer several different ones for cutting & finishing. You can use any pad you'd like as it's a very versatile product. UNO works great with MicroFiber pads too btw.
Weird - but I can finish out 95% of the time with just the MF cutting pads. And that's with a PCXP. Now, these are daily drivers, not show cars, but I still don't see any swirls/marring.
Is there a certain technique to getting it to finish out? Different speeds for correcting and finishing?
With the MF pads, you only need 3-4 small drops. Work the product in @ speed 4 to an 18/18 inch area. Then raise the machine speed to 6 and apply medium pressure with slow overlapping passes. Spur/brush/blow off you pad and apply 1 small drop to the pad and then apply firm pressure at speed 4 for 1-2 very slow passes. This will refine the pad/product marring from the cutting phase and usually leave a very nice finish.
I was just messing with the new 3d pads (all three flat 5.5 inches) on my DA, I like them. I really like the stiffness of the interface pad; keeps a nice flat surface in contact with the paint and doesn't soften up a lot as the pad warms. Hard to tell how they compare to the mf discs (which ive been using like 99% of the time lately) yet, but so far so good.
