fergnation said:I can wash a caar in ten minutes. Literally the guy can pull up in the driveway, go inside and when he comes back out the car is perfectly clean.
Rob Tomlin said:You were right!!
I tried it. I was impressed.
Here is my opinion:
2) It will be harder to tell how well your LSP is holding up in terms of water beading/sheeting than using a regular wash.
:up
Well then it wouldn't work at all!I wish someone would make a product like this "without" the protectant. 90% of the time I only use No-rinse products prior to a polishing session so this type of contamination is of no concern...
Bunky said:10 minutes seems too fast.
Rob Tomlin said:2) It will be harder to tell how well your LSP is holding up in terms of water beading/sheeting than using a regular wash.
Scottwax said:All my details start with ONR...![]()
Chronos said:How does this stuff work exactly? Is it like a QD just spray on and wipe off with a MF towel? Or do you spray, work it in like a soap, wipe off with some trash MF/paper towels, then respray with QD?
Macruz19 said:As for drying using ONR, I use 1 WW 16x24 towel to get the car completely dry. I think it helps when you wash the whole car first and then start drying.
Rob Tomlin said:I personally would never do that.
Macruz19 said:I do that because i'm in the garage away from the sun![]()
