imported_Sarge1
Hello to all! I ran across this site about 2 weeks ago and really enjoyed what I was reading. Forum members here are very patient with the noobs and that's a good thing. We all start somewhere. I also noted that the crew here seems to be a little less rowdy and more professional from the other forums I have visited. :xyxthumbs
If I may, I'd like to address a problem that I think I have under control but will surely solicit your advice. I have a Black 2001 Z Corvette that I really started to get into the detailing bug about recently and it seems that I will keep the fever as I now enjoy detailing my car much more so than before, simply because I the advice I've gleened over the past two weeks. Much easier sequence of events you all use to do things.
I have the swirl/scratch issue that so many have and have taken the appropriate (at least I think so) steps to get things straightened out.
I recently purchased a PC 7424 and separately purchased the flexible 5" backing plate. I found the 5" plate keeps a safe distance from the edges of the LC pads that I've been using with the Menzerna twins.
The car was throughly washed with a degreaser to remove all remaining wax residue. Car was clayed then washed again, dried with MF towel. I started out the project on the rear lower l/s bumper of the car. Nice and inconspicous! I mounted the white LC pad and applied a liberal amount of IP and began to work it in ensuring to properly breakdown the polish (time/speed). Initial results yielded very minor scratches removed yet many remained. I reapplied IP several more times (little more pressure on PC) with approx the same results.
I did not use the FP as the scratches are still there. All of which are far from being noted with the fingernail test. I have a small halogen light that I use to check progress.
I've read that going more abrasive should be done in two different steps. First try a more abrasive pad (yellow:nixweiss)
before trying a more abrasive product. Should I go yellow pad with the IP again or try a more abrasive product with current white pad.
Your input is appreciated!
