SuperBee364
codiddy said:supe, there is a brand of soap called LAVA, you can buy two bars for like 99c cents at walmart. It is a bar soap with lots of pumice and grit embedded. I have yet to find anything it won't take off my hands quickly. you should try and find some and do an experiment on if it is strong enough to take off vintage.
Also about whether it uses more wax to apply with your hand, shouldn't a hand absorb less of the wax than an applicator while also warming up the wax and making it easier to apply a thin coat? I assume thats why they recommend hand application, It makes sense to me.
I haven't seen LAVA soap around for years.. yeah, i bet that stuff would make quick work of the wax.
I think you're right on about the application method. The other thing about the wax... The flakes of wax (you can actually feel the gritty pieces of wax when you first take it out of the container) need to melt in your hand before you apply it to the car. You also need to rub the stuff around in your hands a bit to mix the melted wax into the solvents really well. It's kinda hard to explain well, but after you do it one time you think "oh, yeah, i get it.. so that''s how it works". Using an applicator wouldn't allow you to melt the wax flakes first.
