What I have always found interesting is that a lot of people have switched from a leaf blower to the Metro Master Blaster and I have never heard one person say that they regretted it.
Leaf Blowers work fine, and while there is some risk, it is minimal. However at the end of the day, even with the price that this super high quality machine deserves, everybody who has made the switch was glad they did it. Sometimes that says more than any review could.
I agree with you completely Todd.
Two major advantages of using a leaf blower is they supply large amounts of focused air and they are reasonably priced, around $50.00 on average for an electric model and twice this amount for a gas model.
The downside is they're cumbersome, become somewhat heavy all of a sudden, have a hard plastic tip, and they do not filter the air.
The Metro Master Blaster is well built and a top notch performer. It's hose is lightweight, flexible, and uses a soft rubber nozzle. It's air is filtered and warmed as it passes the motor, a very nice feature.
The Metro Master Blaster lends itself very well to selectively targeting those hard to reach areas without putting additional strain on the user. I think it's performance and customer satisfaction speak volumes as to the quality and performance of this machine.
The major detraction of Metro's Master Blaster is the initial cost. At $400 it pushes the financial limits of many but if the regular price was reduced close to $250 I would suspect the sales would increase substantially.
Two additional points that deserve mentioning are the current draw and hose length.
Current Draw
With both motors running the Metro's Master Blaster draws 19 amps. While this isn't enormous this unit will require a 20amp circuit to operate properly and safely.
Hose Length
Most if not everyone that details has a vacuum. The vacuums are plentiful and brands like Shop-Vac, Home Depot, and Craftsman probably capture 80% of the market.
Most of these vacuums come standard with a 10' to 12' hose. While these hose lengths are often adequate most of us wish they were longer and we're only vacuuming out the interior or trunk.
The ideal hose length for the Metro Master Blaster would be 15'. This would allow unrestricted access and maneuvering to dry the roof, windshield, rear window and the engine compartment.
With the Master Blaster unit directly in front of the car, a hose measuring 10' will most likely be stretched to the limit reaching the firewall of most vehicles. A hose measuring 15' to 18' would be the ideal length that should be standard with these units...
FEATURES:
• 2 stage dual fan / 2 motors
• 2 speeds / 2 temperatures
• 19 amp
• 10 foot x 1.5 inch commercial strength flexible hose
• 12 foot neoprene cord
• E/Z Change Foam Filter (wash & reuse)
• Sturdy Steel- weighs only 16 lbs.
• One year manufacturers warranty.
