Making Impossible possible car detailing by KC's
BumpersPlus2
Hey ya'll, a couple years ago I got a quart of "Diamond Glaze", I think it was called, from a detail supplier. It was made by a company called Lyknu from Tennessee. It was pink, and smelled like kerosene. Anyway, this stuff was AMAZING!!!!!!!!!! It would make oxidized paint disappear, make blacks dark and deep, excellent one step before a quality topper. This is the only product I bought from this distributor, so he didnt come around much. The last time he came around, back then, he said they werent making that stuff anymore, and I better buy a couple gallons. I thought he was b.s.'n me so I just bought one gallon. Next time he came around, sure enough, didnt carry it anymore. I tried contacting the company through the mail, but no luck. I wish I knew what that stuff was, or a comparable product. It would fill swirls too. I always topped it with paste or liquid carnuba, or liquid glass. It never streaked, no matter the weather. I have since then not found a product that would perform as well as it. Any suggestions? Thank You.
If you go the professional detailing fourms they may be able to help you. From what I can see, this fourm consists more of people who detail their cars and maybe one or two others. The professional detailers fourm is filled with people that own or work in a shop, I am sure they would buy in bulk and they probaly know more of the "commerical" product...
I goofed when copying the image location :rolleyes:
Anyway, I had emailed a potential source of this stuff and here's the response I got . . .
Hey Justin,
If it is the same stuff, I had a friend bring me a quart of the it from a flea market in NC. It was made in New York state. That is all the information that I have. I did try and find the company and I believe that it is closed.
Mike *******</blockquote>
This is the 3rd ride- a full correction detail i did last raya (over a period of 3 days holiday break) on day 3
another good day for detailing & golf too
6 years CRV
scratch before
another teach u a lesson key scratched
more damage by his companion paws
Menu for the day
tools - plenty of all assorted brushes, soft bristle hair brushes, tooth brush.
-ONR Wash - with 3 microfibers
-O Power Clean - (1:1 used as degreaser, 3:1 to remove hard stains like algae, 5:1 paint cleaning & emblem cleaning, 8:1 door jams & stickers remover)
-Clay & ONR as QD for clay (2 ounces for 500 ml water)
paint corrections
-Meguiars M105 & Lake country double side wool (fast & quick) (makita spread 1 & progress to speed 3)
-Level up by Optimum Hyper spray compound & Lake country double cutting pad (makita spread 1 & progress to speed 3)
-Paint glossed with Meguiars M205 & Meguiars soft bun polishing pad (makita spread 1 & progress to speed 3 & regress to speed 2 & finish with speed 1)
Protected by
Optimum Opti seal (15 minutes) & Optimum Car wax (10 minutes)
Head lamp protected by Opti coat
during wash
every emblem is carefully clean (agitating by Power Clean)
closer stains before
brushes off with soft bristle brushes
oxidized algae stained rubbers agitated by Power clean
more agitated pic
brushes off with again with soft bristle brushes again
more
roof rubber lining stains before
power clean sprayed on to agitate the algae
brushes off with Tooth brushes- a great recycle idea
another algae oxidized rubber stains
brush off by soft bristle brushes
ta da
cleaning hard to reach area
make easy by delicate tooth brush
after a good good wash
surface preparation works begin
look at the surface contaminations picked up with clay
contaminations picked up side body area
Pic before
continue brushing off & agitating with Power Clean
tada
now a how a detail wiper dispenser should look like
what do you do when your pet suppose to guard yr house damaged yr paint?
i) shoot him
ii) Sue him
iii) do both
vi) detail it
more visible damage by his companion paws
before
during surgery
on the engine hood
a 50/50% comparison before
before pic
the3 perfect 50/50% - on the line
50/50
50/50
after
special pad for special & timid narrow areas correction
Passenger door before
ta da
Another Impossible possible
moving on damaged oxidised head lamp
closer pic
take a closer look
extreme close look.....cracks
side view
correction begins - sand down with 1000 grit sand paper - follow by 1200 grit & 1500 grits - ending with 2000 grits
although is fine but the deeper crack need to be levelled out by continues of 800 grit sand paper
continuous right side
sanding
sanded
close up cracks
continue sanding
the amount of oxidized plastic removed.....safety measure taken to protect unaffected area
sanded
sanding to help to levelled up the damaged
50/50%
after
before
the prefect 3" pad
polished by the specially flown in pads from US lakers....Lake country
for it takes a cobbler to know his tools
ta da
tada
side view
now
extreme close up before & now
Now
remember before
A restored head lamp
ta da
ta da
this head lamp is coated & protected by Opticoat (one time applications)
opps
solve one thing & created another
tape marks...but easily removed by Optimum power clean again
just before the rubber hits the road again
after paint correct, another quick ONR wash given - so easy & effective
if it is not of ONR - i would have given up mobile detailing - imagine the amount of mess & water required for each detailing - at times is 3-4 washes
ta da
the prefect moment of show & shine
side view
low view
top view
a restored head lamp
right side lamp
close up pic
elegantly yours
once was bruised by his best pal
now
reflection & gloss restored
remember before
now
remember before
50/50%
a beautiful moments ...happily ever after
remember this pic
tada
the right side of the ride
have a great week ahead
we caught the vandaliser
making Impossible possible because of our passion make possible
thanks to my buddy Liew who came along the way...we had great time detailing around
that is an amazing recovery........wonderful job man.............
headlight looks like brand new.....awesome overall restore!!!!!
Now is important to remember the client not to left more hotdogs inside the minivan..... :Christmas Hat:
thank you sir
LOL :White Horse:no more hotdogs in the ride
