Stokdgs
dansautodetailing.com
If you only have 4 pads, that is a big problem... You can never do all the steps with just 4 pads... Again, the pads load up with product, and even after wiping them down after you finish the set of passes, they will still eventually get all clogged up with gunk from the process and will not work right..
You need to have a Lot of each pad, and use them as needed, to keep a clean as possible one on the work... I might go through 12+ pads on a vehicle, depending on what is wanted, and how bad the paintwork is, to start...
You need to have a dedicated foam pad cleaner... I have had great success with this for over 15 years --- Snappy Clean Pad Cleaning Powder 3 Pack
If you are using Microfiber for wipe off, you need a good cleaner for them too... I have had great success with Chemical Guys Microfiber Cleaner in the gallon jug..
If you wash and dry the microfiber with Anything else that, is not microfiber, you will get a lot of unwanted junk trapped in the microfiber, so think about that part too..
You are using too big a pad for automotive/truck work.. I only use 5" pads for about everything and smaller down to 1 inch for tiny places, etc...The 5 " pad is much easier to control, get into more places, and is for me, easier to monitor the heat vs, moisture part of this process..
I only used 6 inch pads when I was paint correcting airplanes, which have a way different type of paint on them on them and airplane paint can take higher speeds and not hurt it... But, the higher speeds add a lot more heat and throw more stuff farther away, that has to be cleaned up later... And,you end up killing dozens of pads on airplane paint..
You should see about them getting you a real paint cleaner spray to use for cleaning the panel of unwanted oils, fillers, etc., that come with most paint correction products... This product might be a good one to use to clean the paint after correcting it to make sure, it`s all good or not... RUPES REVEAL LITE Residue Remover
I am so sorry that your instructor was such an idiot by not teaching you how to paint correct because he hated it...Guess he really does not like doing this craft, because no matter what, body work, painting and paint correction will Always be tied together...
Good luck !
Dan F
Good luck !
Dan F
