Labocosmetica
The way I see it, the majority of Autopians and Geeks much prefer buckets over using one, that’s why I asked.
Labocosmetica Preludio as hit the market. It`s on labocosmetica`s main site.
I will be picking up the alkaline one for sure.
You spray it on the panel, let it dwell for a bit and then go straight to the rinseless wash. Sounds great in theory..to get a lot more cleaning power than a standard rinseless.
I love me some rinseless, i haven`t used regular soap in over a year.
You might be able to do the same thing with alot of APC`s...never thought of it before.
I might even try it will 3D orange degreaser......thinking out loud...cut 20:1 and then cleaning it off with the rinseless i think would be safe on paint. Same thing i do on my interior actually lol
Just for the more soiled parts i`m thinking.
hmmm
Let us know how it works. Idrosave is going to be my dedicated winter wash because of the added protection, but a strong pre-rinse to pair with it would be very helpful when dealing with Upstate NY salt and winter grime.
I wonder how it would pair with other brands rinseless washes too.
Valugard kit #M32 -sold as one kit-$110.73. One kit will do 15 to 17 vehicles when directions are followed. Kit is still produced private label for Ford and is in other vehicle manufacturers in their TSB`s, Proven safe and effective since 1995.
All are gallons, however the "C" Detail Wash only requires 1 ounce per vehicle, which means the user has enough detail/car wash for over 100 additional washes! Yes it can be used in a foam application. When mixed as per directions it`s ph is neutral. Over all a big savings.
All in gallons.
Finally have Preludio alkaline coming. Very excited to try it but i will still give my car a quick rinse with the hose unless it`s light cleaning. I also got idrosave simply because the
surfactants in DIY foam up if you use it with Preludio Alkaline - i have a gallon of DIY. I`ll still try it with DIY because i rather use a spray sealant than a wash and coat.
And i finally ordered Fiero! Why i never bought this 2-3 years ago i don`t know, Well i wanted to use up my polishes...
Fiero needs no panel wipe before your LSP so i don`t have to buy or use a panel prep anymore - polish, wipe off and a spray sealant done.. It will be my main polish going forward. I only need a light polish. I polish my car much more than most here i suspect. My bonnet for instance has been polished over 10x for sure.
Update: Recently used fiero and Idrosave. Labocosmetica is legit.
The sealant i used bonded to fiero just fine and well what can i say about Idrosave! Very nice beads and its going strong after 4 weeks.
Special brand.
This combo is still going pretty well. The sealant was NV car care boost V2. I applied it over fiero with no panel prep within 15 minutes on each panel.
Good stuff.
But now i'm very interested in the new OPT, AIO. I love the idea of spraying an AIO directly on the panel that can actually cut some swirls.
Update: About 4 weeks ago i clayed my trunk lid with the rag companies blue clay/scubber and idrosave cut 1:100 and its still beading nicely. Very small subltle beads which i kinda like.
Very impressesd. I think you can use Idrosave as a long lasting detailer.
Next time i wash with Idrosave i will use a dilution of 1:100 for a drying aid or maybe a little stronger i seen some guys mentioned 1:60 is a good ratio to use it has a light sealant which as nice beads.
