Labocosmetica
So it looks like labocosmetica has another gem in the prep spray prior to a coating/sealant. From what i used anyhow. Eraser and gyeon prep are RTU.
It`s called veritas and for removing polish residue the suggested dilution ratio is 1:3-1:5. It`s not IPA based either.
I`m a big fan of concentrates. And it seems much stronger than something like gyeon prep.
I just remembered the mother`s CMX 3-in-1 polish and coat. Has anyone used it?
I was going to suggest this. I use this and it works great for me. I used it under the Infinity Wax Synergy Lite as a tough test, going out into pouring rain within 30 minutes or so and the coating worked great and was working very well 8 months later with very little reduction in performance.
I will say that Labocosmetica are an incredible brand though. Highly innovative and high quality. Pioneers of the 3pH wash system and Purifica, the best acidic car shampoo amongst other things.
Yeah i`m a big fan of labo. I should go to my local hardware store and see if they have the mothers. I looked for it a few times online basically due to you and sheepstars recommendations.
Off topic but i think the new DW layout will be the end of the forum. It`s junk.
Between the 3 remaining forums - regular users - we should all start promoting the forums to the young gen. For me that would be facebook. There is such nonsense there but some people are sincerely looking for solid advice...Your somewhat more accountable on a forum as well so people can weed out the trolls fairly easy.
Slowly steps away from the soapbox....:D
I`ve enjoyed forums since the early 2000`s. My first was weight training based and i join many more after that. It`s such a shame...
Used Omnia 1:10, Hydra 1:4 lastnight on my newest black plastic/vinyl waterproof workboots from Keen. They look fantastic. I will use the same combo on my dash tomorrow.
Labocosmetica even has a concentrated iron remover.
Very nice brand if you like concentrates and the shelf appeal is very good.
It looks like you can now buy direct from Labocosmetica in the US with very reasonable shipping fees. If Carpro`s 3PH wash isn`t up to the task of decontaminating my coating after an Upstate NY winter I`ll give Labocosmetica`s a try (or just Purifica). Hopefully it will and if it does I might still get Semper when I finish of my bottle of Carpro Reset. I`m also running low on Gtechniq I2 Tri-clean I`ll probably give Omnia 2.0 a try too.
Just not sure of that site. When you go to Labocosmetica website and go to purchase in US it redirects you to clean and shiny in the UK.
Funny they would no link to us supplier…
Forum rules says I can`t link the Labocosmetica site I was looking at but when I went to my cart to check shipping it knew what state I was in and was only $7.50 shipping for a 1L bottle of Purifica. It went up from there the more I added. Sill better than the baseline $25 of the site mentioned last Fall.
I found that site but it’s not linked to Labo’s home site. If it were a auth distributor I would think it would link when you choose USA but instead it goes to clean and shiny in UK
The place in Eddie`s video is who I ordered from. The order was processed by and shipped from the official Canadian distributor in Quebec. So long as you`re ok with a small charge on your credit card for an international transaction there`s finally a place to buy Labocosmetica products.
Wish I had seen his video before and saved myself the 15%. I can use it on my next order though so long as the code is still good then.
Primus and Purifica are like half the price of descale and lift in Canada, excluding gallons(not sure about that) Primus is a very nice product too - Great smelling products.
Eddie even said the iron remover is not to bad(smell), it will be my next iron remover for sure and i will be buying the panel prep concentrate too and maybe even fiero - A light primer polish that you don`t have to wait to cure before you apply your LSP. One of their pricer products...
I have leale now and it works fine with a nice wipeoff. Very close to perfect finish in that regard.
Eddie even said the iron remover is not to bad, it will be my next iron remover for sure and…
The Iron Remover is nice, a bit thicker and clingier than others which is, for me, a plus.
Have some #Chronos on the way; Cayman soots up the tailpipes pretty good so hoping for spray/rinse goodness.
Sent from my iPhone using Tapatalk Pro
Did you also order from same website?
I`ve now bought Primus, Purifica, Cronos, and Sidero from there. All arrived in 2-4 days with samples of Revitax in one and Hydra in the other. Fingers crossed when I get the chance to use Primus and Purifica they bring back the hydrophobics of 22PLE HPC that I applied this past July which Carpro Lift and Descale were not able to. I managed forget about the 15% off code again. Maybe I`ll remember next time if/when I order Semper when I run out of Reset and Siramik SC Wash.
Worst case if Labocometica`s 3PH wash doesn`t restore 22PLE HPC I now have Siramik`s Lustrous Plus Graphene Spray to top it with after getting in touch with SiRamik through Facebook. The shipping was terribly expensive from England to the US but that spray looks to be amazing. I also bought their shampoo and tire shine.
FYI purifica worked great with the new clay scubber from TRC. I cut it %10/vol in a spray bottle and lightly sprayed the panels with my hose before i started claying. Some sections i done i started to see brownish color. From my reading of labocosmetica they stated this about the anti-limescale action of their iron remover Sidero:
" It is also the first iron remover capable of eliminating at the same time, in a single operation, even the residues of limestone. In fact, when there are mineral residues, its color changes from purple to dark green – bronze precisely to indicate the elimination of calcium residues. The product is inert on the bodywork , the bumpers and the plastic parts, restores to the protective applied previously its original beading effect. Thanks to an exclusive and extremely effective blend, SIDERO is able to dissolve stains of rust and, for this reason, it is also recommended for the world nautical. It is essential for the extraordinary cleaning internal rims before the protective treatment coating."
I`m thinking purifica as the same color changing chemical.
Anyhow, i was very impressed it made my car look freshly polished from a distance.
