Is a 6 1/2 horsepower shop vac strong enough?
I am going to be cleaning some very very bad interiors. Will a 6 1/5 horsepower shop vac be strong enough to suck all the black grime out of the rugs?
I just hope I have a cleaner up to the task. I can't find the Prestone carpet cleaner in ANY store within a 60 mile radius of me. Trust me, I've looked.
The Hp limit on a 120Vac 15 amp outlet is approximately 2.4 Hp. Anything more and the circuit breaker will trip.
For 240 VAC and 20 amp outlet max approximate is 6.4 Hp.
So why don't people just go out and buy 2.4 HP vacs? They all buy the 6 + hp models.
Your telling me I will never run above 2.4 HP???
I don't know, it doesn't sound like 2.4 HP is strong enough to do a decent job.
Maybe it is Marketing Hp or something. I cannot explain it but I thought I would bring it to your attention.
I think you will find most vacs work well enough if you brush the carpet first with a carpet brush and vacuum often.
I use a little 5gallon Shop vac and it works fine which on the box says peaks at 1.5 hp.
Too really check the vacs I say read the motor label as it will give an amperage & volt rating of the motor. This info can be used to calc actual motor Hp.
FWIW, I had a 1.5HP Craftsman Shop Vac a few years ago, and it was the worst vacuum I ever had. My parent's Electrolux canister vac had more power than that thing did. It wouldn't suck-up the dirt, it just sort of lifted and repositioned it...
So, I bought a 5.25 HP Craftsman, and I love it - the thing would suck the paint off of my house if I got it too close. But I'm confused - If it's only running at around 2.5 HP, how can it be sooooo much stronger than the other one??? :confused:
Design of the fan, hose diameter, hose length, hose end, extension cord wire gage are some factors that will affect vacuuming.
Geek when you get back home read the motor nameplate and post what it says about volts and amps.
Thanks for the info about the models you own as well as the amp/volt ratings. I will be sure to check them out. I think I'll end up buying one of the 6 + horsepower models. You should see the rugs I need to clean, they have the car for 3-5 years and never had it shampoo'd. They are really really bad.
8.0 amps at 120 VAC = 1.29 Hp.
Here is the formula for AC voltage single phase motors:
Amps x Voltsx x PF = watts
Where PF = power factor (I use 1.0 to give maximum watt ratings)
Now 1 watt = .00134 Hp
This is all straight from an electric handbook.
For 3 phase motors:
1.73 x amps x Volts x PF
I bet when they say Hp they mean peak like for a millisecond. I wonder what they are refering too.
I'm not using anything that can suck the paint off a house on my headliner or my upholstery, that's just me. IMO, 6/5 is a enough on our cars.
I have a 7 amp, 3.0 peak HP Shop Vac that is noticably stronger than the 1.5 peak HP one I used to have and on par with the (discontinued) Sears model that finally died on me a few weeks ago.
The 3.0 HP vac is more than strong enough to lift the mats up off the carpet.
I am not to quick with these amps, voltages, marketing types of stuff, but I can tell you there is a big difference between my 2 gallon 1.5 hp protable vac and the 16 gallon 6.25 hp vac mentioned at the start of this thread.
This 16 gallon vac really sucks! Literally it SUCKS well!
I give it my thumbs up. :up
(Hopefully we are talking about the Rigid 16 gallon 6.25 hp Shop Vac.)
I have a huge wet dry vac, sometimes it can suck jason up if i am not looking around to see what i am doing.
speaking of vacuums, did everyone see the movie "scary movie" when he uses the vacuum cleaner to please him self.. one of the funniest movies i have seen.
<em class='bbc'>Originally posted by NY detailer [/i]
<strong class='bbc'>speaking of vacuums, did everyone see the movie "scary movie" when he uses the vacuum cleaner to please him self.. one of the funniest movies i have seen. [/b]</blockquote>The guys and I were just talking about that very scene at dinner a little while ago. What a coincidence! :wavey
I'd rather use a Real Doll®!
"...how many times have I told you not to bother me when I'm cleaning my room!" that line (if that's it) is the funniest :D
<strong class='bbc'>I have a huge wet dry vac, sometimes it can suck jason up if i am not looking around to see what i am doing.[/b]</blockquote>
Oh man hahahaha you and Jason crack me up man. Yea Jason is the joking type ............ yeah :rolleyes: ;)
