bill57 said:I still go with good old fashioned incandescent light. The high tech stuff is theoretically better, but in the real world of human eyesight and practical application, I find that incandescent light shows all the defects one needs to see.
addysdaddy said:This is one of those elusive items that you wind up buying a 100 different things but nothing quite does the job..
TOGWT said:[Any ideas why different coloured cars react differently to various light sources]
The surface colour affects the way light is reflected from the surface, the lighter the colour (White / Silver) the higher the reflection and vies versa
Reflective Value (RV) - the reflective value of a colour indicates how much light and heat is reflected back from the colour surface.
Light reflectance value (LRV) is a numerical rating assigned by paint manufacturers to each colour they make. This number is a scientifically determined assessment of the amount light and heat that colour will reflect on a scale of 0 to 100.
The average blackest black has a light reflection value (LRV) of approximately 5% and the purest white is approximately 85%. Some yellows can measure up into the 80's or 90's as well. All colours fit in between these two extremes.
Bill D said:I bought a battery operated Black and Decker LED spotlight but I'm going to return it. It doesn't perfrom quite as bright/ the same as the original one Barry uses. I'll stay tuned to the forums for the next Autopia-approved model.
pwaug said:You can still find the rechargeble Black and Decker (like Barry uses) at some Big Lots and at some Tuesday Mornings (found mine here for $15.00)
addysdaddy said:BARSKA 1200-Lumen High Power LED Flashlight BA11630 B&H Photo
Found this flashlight and though expensive, substantially less then many of the other possibilities discussed on this thread, especially for it's output. I have the HD dual work lights but honestly, it doesn't do the job for me. I'm going to give this hand held a try and will report back with my impressions. If anyone has any thoughts before I buy, please let me know Thanks.
tom p. said:Addy, nice to see you here. This looks like a serious flashlight!
Good luck on your job later today. What color is the car you will b working on? T
someidiot said:Any good recommendations if you DON'T have good ambient lighting? My garage only has the garage door opener, a single incandescent bulb, and 1 bank of fluorescent lights in one corner. It pretty much sucks for trying to see the passenger side or rear of the car...(putting up more garage lighting isn't really an option, I'm a renter..
Before this thread I always thought those halogen worklights were the go-to for everyone and was planning on getting some. Are those preferred if you don't have particularly good garage lighting already?
someidiot said:(putting up more garage lighting isn't really an option, I'm a renter)
And if you use the variety considered "shop lights" they just plug in to a receptical--no direct wiring required. Some even come with small chains to hang them.detailfanatic said:Adding a few more flourescent fixtures would be very inexpensive and they draw nearly zero in the way of power. They would add a lot of light to your garage. Because they are surface mounted, install is dead easy as well.
