TacoHerder
Not sure if it's been said, but I would love to see some pads for removing contamination.
they do make a foam pad with a recess cut out for clay to be inserted in. Paintwork Clay Pad ApplicatorNot sure if it's been said, but I would love to see some pads for removing contamination.
Whhhhaaaaaat, I did not notice that. And wow, that's a pretty clever ideal to use your clay. Well a pad with the stuff like on the speedy prep towel would be a better permanent ideal, otherwise it's back to thinking for me.
I need some new pads..... Believe me
The only thing that comes to mind is that I am eventually going to have to clean the carpet and the upholstery. I don't have a steam cleaner so what came to mind is a pad that has a short bristle on it, say about 1/2" to an 1 inch in length that are soft to medium stiffness. I think it would be slick to be able to work in some carpet cleaner and agitate it with the 6" RO machine before vacuuming it out.
I'd like to see some pads made for the interior... I think a whole new class of pads could be made.
1) Pads for a deep clean for upholstery that can take stains out (to replace what I use now, which is a stiff upholstery brush)
2) Pads for a light clean of upholstery when you don't need as aggressive measures
3) Pads designed to be super soft for leather, yet clean them (ie something to replace the horsehair brush I use)
4) Pads designed to apply protectant (also replacing another horse hair brush I use)
5) Pads designed for vinyl seats
6) Pads designed for cloth seats
7) And finally, pads designed to clean out scuff marks from plastic... the bane of my interior detail!
Brand new here first post, just picked up this hobby for my new Lexus.
I read a lot of great suggestions and seems like almost every idea I had was already mentioned - except 1. The centering hole that rotaries use, you see on wool pads, why not along with making the pad (foam)fit the backing plate perfectly - add a hole in the middle and center it like a wool pad.
What about a brush is round, a little larger than pad size, that sits on a surface and I can quickly use on my pad while on the buffer/polisher at a low
Speed if It gets a little over saturated. I know the grit guard exists but it's a big bucket and for extensive cleanings.
Also what about a dual color pad? The top color and material is as Normal but the second layer is placed so that pad wear level can be checked and monitored, especially by us newbies lol.
I think that a Dual Action wouldn't be able to because the center of the pad changes as the pad oscillates, unlike a rotary where the center is always fixed in one position.
I'm talking about "centering" the pad on the backing plate. If you have used LC wool and a rotary, you know how easy it is to slide the centering tool/plastic thingie in the pad, stick it in the hole on the backing plate and slide the pad down - perfect alignment! On a PC, if you get it to far on one side it'll vibrate more than usual, that's one reason I liked the Edge system - perfect alignment. It seems easy enough to modify the foam, just need some DA backing plates with a center hole like the rotary ones.
