Redcar GUY
anyone tried it by hand, doest it work? I dont have a PC but I do have a 9in craftsman buffer with cottom bonnets. Any info?
Welcome to the forums.
As far as correction you always want to start with the least aggresive combo of products.Start with Megs 205 with a white pad and see if that corrects what you are trying to remove.
If the 205 and white doesn't help move onto a orange pad .Always do a test spot and yes i would do an IPA wipedown after every panel you do .This will remove all the oils left behind and give you a true finish.
The PCXP should be fine do some reading about the KBM method that should help some also.I'm not 100% sure but you clear coat might be the self healing clear coat i believe there is a sticker on the door edge or the b pillar post if it does have that type of clear coat .Everything you listed looks like a plan and i'm sure others will chime in and add parts that i missed .
I agree with Harleyguy. I have been able to get some decent correction with 205. Plus with the 205 I dont think you would need to follow it up with PO85RD on that color. 205 will do a great job on it own. But try it out. IPA would be a good idea before polishing. If you use 205 or 105 you should not need to do a IPA wipe down after polishing.
