PorscheGuy997
JohnKleven said:Since you can achieve better results much quicker with a rotary, or even a flex dual action polisher.
Quite the opinion there... Have you even tried a non-diminishing abrasive polish?
JohnKleven said:I HATE the PC polisher..
Shiny Lil Detlr said:why do you "HATE" the PC?
Accumulator said:-AND-
I'm sure no fan of the original PC either. Way too much vibration and seriously underpowered. Haven't tried the XP, but I gotta say that the Griot's 6" RO is *SO* superior to the PC that it's almost silly to consider them members of the same category. While I'll admit I simply don't like my rotaries, I used to reach for them when I needed to do serious correction on hard clear; no need for that any more, though I will say that a rotary teamed with rocks-in-a-bottle can do some very serious work in one quick pass.
smoknfastlegend said:Don't get rid of your pc's, put them to use pushing 3" pads so you don't have to constantly switch backing plates.
Guitarist302008 said:Your friend is wrong... it's really that simple... while I prefer the Flex over a PC, still the same idea but a bit faster. As I said though your friend is wrong and also a moron. It CAN and DOES remove scratches and swirls. If you want to argue the time it takes then that's perfectly fine, but to say it doesn't work is pure ignorance.
mikenap said:LOL, that's some pretty harsh words right there. Did you see the date of the original post or read any of the prior posts? This thread is almost 3 years old, and a LOT has changed in that time. Even big names like Todd Helme, David Fermani and Rydawg were on board with the fact that a PC just couldn't cut it (no pun intended) back then. With the advent of 105, Surbufs, MF pads and the KBM, facts and opinions changed, and a lot of these guys have adopted the PC as their main machine now. I think this is why David bumped this thread in the first place. Take it for what it is, an interesting read into how quickly things change in the industry and how people must change with it or get left behind.
Nth Degree said:This was a fun read. I would like to hear, now, from those who posted their thoughts at the start of this thread and what their opinions are now and how they feel about their statements from 3 years ago.:boink:opcorn:
Accumulator said:...I actually worry a little....it's *so* easy for anybody to cut off clear while leaving an OK finish that I suspect people are gonna do a lot of overthinning...
Kevin Brown said:Tell that to lady that cuts what's left of my hair. :think:
(Que the large inhaling sound) ...When these new fangled non-diminishing super-micro abrasive compounds and polishes are applied with microfiber polishing discs (featuring ultra thin microfiber strands) mounted to oh-so forgiving random orbitals operated by typically intelligent folk... the cut will eventually slow or "self regulate" the more refined or polished the surface becomes (all assuming that the guy polishing the paint isn't banking the pad at a 45 degree angle or applying enough force to blow a new set of tires on a Boeing 787 Dreamliner) .
C. Charles Hahn said:But.... aren't you the guy who advocates "edging" the pad at an angle in order to increase cut and remove deeper defects? (Granted, the qualifier is you're talking to people who are experienced in paint correction when suggesting that....)
Kevin Brown said:Not 45 degrees!!!
I coulda' swore I mentioned it would essentially slow the cut so long as the pad was kept level with the polishing surface, but apparently I didn't! Oops. :knockout:
C. Charles Hahn said:Yeah, 45 degrees is a bit of an exaggeration.
I kinda figured that's what you meant since putting the pad toward its edge does work to increase cut instead of decreasing it, but I wanted to be sure.
