I sand and buff Nason clear all the time at work. Most body men use 1000 or 1500 and that's it. VERY few body shops are going to spend the extra time working their way up to 3 or 4000 grit when there are compounds like 3M Perfect It 2 that will easily cut 1000 grit scratches with a wool pad. I've tryed the "sand for 2 days with 5 differant grits" method and to be honest there were no differance in the results. If you've got a rotary and wool pad, and know what your doing, just do it. Yes its going to swirl up, but that's what foam pads and high quality polish like Poorboys SSR line is for. If the shop is already going to have it sanded down to 4000, a fine compound such as 3M Perfect It 3, or an aggressive polish should work just fine with a foam cutting pad. Wool won't be nessessary for such fine scratches. I'm not in any way trying to start a wetsanding war in here..for the record. Just my two cents from years of experience in this field.
