jbjwallace
The velcro on HF pads are only 5" they will work just fine on the HF backing plate. Wrong they need a 5" backing plate and the pads will work:hmph:
Shane.belzers said:How did you get that open. I look at the diagram but couldn't figure how to get past the counter weight and so on...
Sent from my GT-N7000 using Tapatalk 2
jbjwallace said:This AM I removed the red front cover of the HF DA and used a grease gun from my chain saw bar sprocket
and filled the cavity with out removing the bearings etc. turned the polisher on #1 at the same time
putting grease into it, the noise was cut by 2/3
beamerstrumpet said:That is probably the same red grease as we are buying in the can.
czjon said:Thank you for your reply!
What is an LSP? Also is there a dummy youtube channel or video you might recommend for a newbie application and process of cutting with compound, polishing and then the last step with the LSP? I guess that would be sealant of some kind?
Thank you again!!
Jon
