LeMarque
It's on sale again for 49.99
pwaug said:Rob--I have a GG6 which I run with 5.5" pads--it does vibrate, but doesn't seem to bother me after a full day of polishing. If you want something that everyone says is a pleasure to use look at the Rupes--especially the 5" model.
baseball07 said:So the general consensus is that the HF foam pads do not quite fit the 6" backing plate that comes with the machine. So how would the pads fit on to a 5" backing plate? At $4 a pop I would like to find a way to use them.
baseball07 said:Where can I find the plate and foam pads at $5.60 for free shipping?
baseball07 said:Thanks I am going to place an order. This is my first detailing job, and I plan on getting Ultimate Compound and Ultimate Polish. So if I were to buy 5 Buff and Shine Pads, I am thinking 2 orange for UC 2 green polishing pads for the UP. Then I thought maybe a yellow if I needed anything more agressive for some areas then finish with wax by hand. Is this ok for a full detail? I figure 2 pads for each product is ok.
BigAl3 said:at least a minimum of three...
C. Charles Hahn said:Depends how you're cleaning your pads, and how aggressively you're compounding. If you are doing heavy cutting then I'd agree, you need several pads especially if you can't deep-clean them on the fly (e.g. Grit Guard pad washer), but for lighter polishing I can get away with 2 pads per step per car, sometimes even a single pad if I'm just polishing to bump up a little gloss and "correction" isn't needed.
As long as you're taking steps to work clean and unload the paint residue and excess buffing liquid from the pad(s) I find it's possible to push them pretty far before swapping.
pwaug said:Since this is the baseball07's first machine polishing experience and he will be using UC and UP I thought it might be better for him to have more pads than less. Does this make sense???
sulla said:I think Charles is speaking in terms of 'minimizing spending' worst come to worst if baseball choose to give up on the job, it's easy to get discouraged after the first polishing job, deeper rids,sanding marks,beginning clearcoat failure that looks like a haze are among things UC and UP with orange pad cant solve...Besides new kind of pads are coming out so soon nowadays, maybe tempted to get the newer kinds![]()
BigAl3 said:you know what they say Charles.. there are two things you can never have enough of, and that is pads and microfiber towels. sooner or later you will need more (some who are new to paint polishing may over use product and saturate pads). i try to have at least three available for worst case scenerio. i do see what you're saying though...
p.s. how are you doing these days charles? hope all is well...
C. Charles Hahn said:I'm doing well, thanks for asking. Keeping busy and always looking for new opportunities.
